2 replies to this topic
  • New Member
  • Pip
  • 3 posts
  • Ford Model: 2001 MK 6 ESCORT FINESSE
Posted 16 March 2009 - 10:12 PM
Hi im new here and wanted to know if there is anyway i can out if my late (y reg 2001) escort has a heated front screen wiring loom fitted?? How do i find out??
Also how hard is it to change all my dash bulbs to blue led`s and how do i do it??
Cheers for any feedback recieved.
Have something to contribute?
#2 ant1985
  • New Member
  • Pip
  • 9 posts
  • Ford Model: escort
Posted 20 March 2009 - 09:54 PM
hi im new to this but if you take the dash plastic off. remove the 2 screws by the clocks and remove plastic its just clipped on and where the rear heated switch is there should be another loom taped to it and thats the front heated loom. hope this help jayjayuk82
#3 mr.c
  • New Member
  • PipPip
  • 14 posts
  • Ford Model: Escort MK5
Posted 24 March 2009 - 07:45 PM
You need to take off the plastic covers that run down each side of the front windscreen. to see if the wiring is there. just because there is a plug at the back of the dash for the switch to plug into - that itself just goes to the fuse box. it doesnt mean the wires from the fuse box to the windscreen are there!
Then you have to make sure you have the right fuse box with all the relays and fuses to power it because in my experience i have had mk5 and mk6 escorts there must be 20 different fuse boxes!
If you want to put blue LEDs in i would find a second hand set of clocks, and experiement with them as its not as easy as you might think.
Not what you're looking for?
