Pirategirl Posted March 8, 2013 Share Posted March 8, 2013 Hey guys, Can you just confirm for me the psi on the tyres for a 56' Reg focus? Is it 30 on the front and 32 on the back? Think one of my valves is bust as it doesn't seem to want to inflate. Thank you :) Quote Link to comment Share on other sites More sharing options...
Dal. Posted March 8, 2013 Share Posted March 8, 2013 It depends on your tyre size but that sounds about right. Check here to see what your tyres are recommended: http://www.puretyre.co.uk/ford-tyre-pressures/ You can always go up or down a few depending on how you like the handling. Quote Link to comment Share on other sites More sharing options...
Pirategirl Posted March 8, 2013 Author Share Posted March 8, 2013 Thanks for that, I shall check. Think I need a new tyre anyway, but is always good know! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 10, 2013 Share Posted March 10, 2013 There should be a tyre pressure chart listing pressures by tyre size and vehicle loading below the door catch on the drivers side B pillar. The label looks something like this- Pressures are always quoted for cold tyres, i usually add 2psi on top of my pressure to allow for warm tyres if i pump them up at a garage. The pressures are listed in Bar (1 bar equals air pressure at sea level), pounds per square inch, and kilopascals ( .0001 bar). I personally find it easiest to keep everything in psi. My work car (Police dog carrying Focus estate) is recommended to 35psi rear and 32psi front due to a lot of weight in the back but my personal Focus is always set to 31psi front and back. Quote Link to comment Share on other sites More sharing options...
