Pumaspeed Performance Down Pipe
1 reply to this topic
#1 Jwsturner
Jwsturner
  • 97 posts
  • Name: James
  • Ford Model: MK7 1.6 TDCI Titanium 5 door
  • Year: 2009
Posted 08 March 2013 - 08:50 PM
Has anyone fitted the Pumaspeed down pipe on a 1.6 tdci 90bhp Fez?
http://www.pumaspeed...ON-DPF_1142.jsp
Are the gains as good as it says?
#2 FOCA
FOCA
    Feet On The Table
  • 830 posts
  • Name: FOCA
  • Ford Model: Ford Mondeo
  • Year: Non
Posted 08 March 2013 - 09:39 PM
What gains?
Iv read through it and could not see any claims or figures
Although there are no actual figures in general i would expect a significant improvement in performance with the pumaspeed performance downpipe (i would cal it a decat decat/ downpipe)
The cat on these cars is very restrictive, demoving it and replacing it with a pipe reduces the back-pressure(downstream of the turbine) / improves gas flow and scavenging on the turbine (the exhaust part of the turbo)
 - because the turbine spools up quicker the compressor spools up quicker too
(reducing lag/ improving throttle response) so the boost comes in quicker - improving midrange torque/ power - the actual peak boost pressure stays the same (it is controlled by the actuator/ ECU/ wastegate or VNT) so its safe, the cat is not nessesary for a UK MOT at present
The free -flow (scavenging/ breathing) of the exhaust gasses helps the top end power helps the engine rev
Its a bit expensive for a decat, but you get a decat, downpipe and flexi in one unit
Probably to get the full benifit of this, you would need a performance exhaust (replace the restrictive baffles with "straight-through" silencers) and a remap as well as improvements to the air intake - all these things together woud probably give "serious" gains
(a remap at the least - because it would give the biggest gain for the least outlay)
An injector upgrade, larger FMIC and hybrid (larger) turbo set up right could potentially give 140-150hp i recon though these things would be expensive and not shure about the cost effectiveness.
