Help Mondeo Has Died And Wont Start!
13 replies to this topic
#1 davo123
davo123
    Member
  • PipPip
  • 13 posts
  • Ford Model: mondeo 2.0 petrol auto 2002
Posted 10 March 2013 - 11:49 AM
Ok ford gurus please help me,mondeo 2.0duratec was driving along stopped at traff lights and car cut out,wouldnt quite start,would turn over and some times ran with very very low revs felt like fuel starvation but had 40miles of fuel left in the tank so stuck another 5 litres in as broke down next to a garage ,still no go had new coil plugs and ht leads 1000miles ago checked them all still solid it sometimes almost fires and if you depress the valve on injector rail fuel squirts out so fuel is gettin thru,any ideas? Thanks in advance just bought the car a month ago on ebay so very annoyed. to be clear it turns over and sometimes almost fires but not quite
#2 davo123
davo123
    Member
  • PipPip
  • 13 posts
Posted 10 March 2013 - 01:37 PM
I should add called aa out the guy reckoned chain had slipped!? Took cover off and theres a bit of play in the chain anyway i can test for this? To me it feels like a fuel pump problem anybody no how i can test fuel pressure without a pressure tester?also seems more closer to starting with accelerator pushed right down....
#3 davo123
davo123
    Member
  • PipPip
  • 13 posts
Posted 10 March 2013 - 02:45 PM
Ok so its not fuel pump,so im guessing its camchain has slipped it was a bit tappity sounding.
it happened whilst stopped at traf lights any chance it hasnt buggereed the valves etc?also ive tried to start it lots which prob hasnt helped...any advice or help would really be appreciated......is this the end of the car? Somebody?anybody?
#4 davo123
davo123
    Member
  • PipPip
  • 13 posts
Posted 10 March 2013 - 06:22 PM
Has anybody ever had a chain slip? What happened? Did it mean the end of the engine? Has anybody got any input at all? Could anyone tell me if this engine is an interferance engine or not?
#5 wase16ll
wase16ll
  • 280 posts
  • Name: Tony
  • Ford Model: granada
  • Year: 1992
Posted 10 March 2013 - 06:57 PM
are you getting a good spark from coil/leads
chain can slip, plus can do damage if it does.
can either physicly check timing, or do a compression test.
when foot is flat on accelerator, this will cut fuel supply, so if it appears to try and start better when you do this, is it possible engine is flooded...might be worth whipping plugs out to have a look
#6 davo123
davo123
    Member
  • PipPip
  • 13 posts
Posted 10 March 2013 - 07:02 PM
thanks for your reply! I havent checked spark as it sometimes fires,I will fit the old coil tomo and see if it makes a diff how do u check the timing physically?thanks
#7 wase16ll
wase16ll
  • 280 posts
  • Name: Tony
  • Year: 1992
Posted 10 March 2013 - 07:25 PM
ideally, you will need the timing kit, from memory, its only a crank pin and a bar for camshaftts so not expensive.
again, from memory, there is a bolt at front of engine, low down on gearbox side.
turn engine to approx 45 deg before tdc, remove that bolt, fit crank pin in its place.
turn engine slowly, clockwise till crank locks against pin....
remove cam cover, back of camshafts are slotted, if timing is correct you will be able to fit camshaft bar into those slots across the head...if they dont line up. timing has slipped.
pretty sure thats correct
various cheap spark testers on market, just fit them between plug and lead, have someone turn the engine over whilst you watch for good strong spark
#8 wase16ll
wase16ll
  • 280 posts
  • Name: Tony
  • Year: 1992
Posted 10 March 2013 - 07:29 PM
something worth checking....had a few mondeos in the past where the wiring plug to the coil pack plays up....check the connections, pay particular attention to wiring close to plug, had a few wire breakages at that point.
#9 davo123
davo123
    Member
  • PipPip
  • 13 posts
Posted 10 March 2013 - 07:53 PM
Ok so tomo ill check all the wiring and make sure I have a good spark,if that fails I guess i have to make the choice between timing chain kit £115 + 18 for tool,and hope it hasnt done damage, an ebay replacement engine £250 plus postage or scrap it for bits and start again! Also im not a mechanic but a competant diyer which would u choose in my position?engine or kit?
#10 wase16ll
wase16ll
  • 280 posts
  • Name: Tony
  • Year: 1992
Posted 10 March 2013 - 08:14 PM
better off investing in 20/30 quid for tool kit first, you dont know yet if chain has slipped...
its not a common occurance....
can you get a diagnostic plugged in, check for codes
#11 davo123
davo123
    Member
  • PipPip
  • 13 posts
Posted 12 March 2013 - 01:06 PM
Ok so I called the aa out again and this time i got a decent bloke,he tried alot and got it running with ver very low revs say 200rpm for about 20seconds.he took spark plugs out and turned over and it was firing fuel out like no tomo he didnt reckon it was chain as it ran-albeit at 200rpm and like a lumpy bag of mess...his best guess was overfuelling,he plugged in and got no fault codes,temp read 21degrees,would it throw out Fault code if timing chain had slipped?/was out? He said it sounded like it was runnin backwards at one point.any help greatly appreciated
#12 davo123
davo123
    Member
  • PipPip
  • 13 posts
Posted 12 March 2013 - 05:56 PM
ok I have taken a short video of it trying to start and running for approx ten seconds its not great but if it confirms timing chain or helps with a diagnosis....audio isnt great as my phones not the best video is here http://s1327.beta.ph...5b4d79.mp4.html thanks in advance for any advice/opinions and thanks to those who have already posted...
#13 wase16ll
wase16ll
  • 280 posts
  • Name: Tony
  • Year: 1992
Posted 13 March 2013 - 12:17 AM
first thought
camshaft sensor or
map sensor
did the aa check the condition of plugs/coil/leads/spark?
i know you said they were recently replaced, but any failure along those lines can throw up similar symptoms
but to be honest, there are so many possibles with that kind of fault, wouldnt want to suggest throwing money in a try this or try that...
might pay to get a proper diagnosis
#14 ppeter7
ppeter7
  • 199 posts
  • Name: peter
  • Ford Model: mondeo 1.8
  • Year: 2001
Posted 13 March 2013 - 05:47 PM
almost sounds like its firing on 2 cylinders.try taking plugs out 1 at time and turn it over wil some1 checks for spark
