AdBlock Warning
Sign in to follow this
Followers 0
johnson
noise coming from wheel
3 posts in this topic
Yesterday and today a noise seems to be coming from the passenger side front wheel when I am turning corners. It sounds like it is scrapping or grinding on something. It doesn’t happen with every turn, but is quite loud and happens often. I looked at the wheel and cannot see anything obvious what would obstruct the wheel or contribute to the sound. any ideas (in girl terms!!!) what it could be?i only had an mot last week, so seems odd!thanks in advance.
most likely a wheel bearing thats gone
They should of found a wheel bearing problem on mot, more likely to be a constant velocity joint on a drive shaft if it's on slow turns, wheel bearing will rumble on bends and go quiet on the straight....til it gets real bad.
Followers 0
