filbo
Wing Mirror Cover Removal
6 posts in this topic
Would anyone be able to advise about how to remove and replace a wing mirror cover plate for a 2011Fiesta?
Hi It is in the hand book under replacing bulb you have to press it in to and pull just tabs holding it in place but they do break if your fitting a new one look at the tabs to locate the bit you have to press in (side next to window I think)
Hi Dave
Thanks - I don't know why I didn't look inn the handbook. Sometimes the most obvious things are right in front of you!
With all good wishes
Bob
Hi Bob glad I have been of some help.
Dave
ive just removed mine very easy to do , tilt the mirror glass inwards then put your fingers behind the glass then pull off , mine came off quite easy then with the mirror glass removed you can see the 3 top clips that hold the caps on i used a screwdriver to lever and push until the caps unclip.
Hi Karl
Many thanks, I've done the job now but its useful to have the tip about mirror removal - I'm sure this makes things a little easier.
Bob
