selway89
Fiesta 2010 Discs And Pads Change
Just a quick query.
Can anyone confirm for me if a 7mm allen key is required for changing discs and pads on the Fiesta 2010?
I know most Fords do have these but just want to be sure.
Also if anyone knows the recommended torque setting for them that would be great?
Many thanks
James
James I believe all the mk7 no longer use the 7mm Allen key anymore.
They are the sliding pin type with hex head bolts - which should come with your new pads
Oh right ok. I will need to check that when they turn up. I have just ordered a discs and pads set from ebay.
If its a star/torx headed bolt then thats fine.
Thanks for the info.
Jus done the pads on my 2009 1.4 titanium jus needed a 12mm spanner for the 2 bolts.
Cheers for the info. Sounds like I wont need to by a 7mm allen key.
Will be getting round to doing them shortly.
Hi guys quick question. Any got the torque settings for the carrier bolts on the front discs?
Haven't been able to get my hands on a Haynes manual and will be doing the discs and pads tomorrow morning come sunshine or snow! :P
Cheers
James
