What Is This Part?
19 replies to this topic
#16 hormonedmonkey
hormonedmonkey
    Member
  • PipPip
  • 21 posts
  • Name: Asa
  • Ford Model: 2006 Focus TDCI Sport
  • Year: 2006
Posted 02 April 2013 - 09:42 PM
I've removed it which stops the buzzing.
I'm a bit confused what you mean by; "Try just pushing each wire towards the bulkhead"
#17 wase16ll
wase16ll
  • 280 posts
  • Name: Tony
  • Ford Model: granada
  • Year: 1992
Posted 02 April 2013 - 10:05 PM
this is just a connector, the buzzing will be coming from somewhere else...would be a help if you can track where the buzzing is to start with...highly unlikely its the connector itself.
have you tried pulling fuses one at a time to see if/when buzzing stops [might not just be the one fuse, so just make a note of which and how many fuses]...that way at least you narrow it down to a particular cicuit...
once you know the circuit then disconnect the wiring plugs of destination of that cicuit and see if it buzzes when fuse is in place...
for eg...if pulling the fuse for headlights stops the buzz, then replace the fuse and pull the plug on back of headlight and see if that stops it...if it does then check bulb, if it doesnt then inspect the wiring between headlight/fusebox etc etc..
only way forward is process of elimination...you have to start by finding the exact circuit causing the problem.
#18 hormonedmonkey
hormonedmonkey
    Member
  • PipPip
  • 21 posts
  • Name: Asa
  • Year: 2006
Posted 02 April 2013 - 11:12 PM
Thanks. I now have to wait for it to cut out AND do the buzzing thing as it doesnt always do this
#19 hormonedmonkey
hormonedmonkey
    Member
  • PipPip
  • 21 posts
  • Name: Asa
  • Year: 2006
Posted 03 April 2013 - 11:56 AM
Lots have suggested bad earth?
#20 artscot79
artscot79
  • PipPipPipPipPip
  • 5,329 posts
  • Name: arthur
  • Year: 2006
Posted 03 April 2013 - 12:17 PM
try the engine bay fuse box if theres water in there or a faulty relay it will feed through
