Eggy1990 Posted March 23, 2013 Share Posted March 23, 2013 Morning all, I've purshaced a 1.0 ecoboost 100ps zetec,I was under the impression that when I was driving along I would get a shift indicator for up and down gears I'm yet to see it come on, is it something that wouldn't be standard or just turned off? I've looked in the manual and it is there on pg65 Help appreciated Cheers! Quote Link to comment Share on other sites More sharing options...
FOCA Posted March 23, 2013 Share Posted March 23, 2013 You might have to rev the engine a bit more/ higher to see it come on (some call it a "shift light") I don't know exactly at what revs it comes on but it may be a good idea to run it in a bit 1st Quote Link to comment Share on other sites More sharing options...
Eggy1990 Posted March 23, 2013 Author Share Posted March 23, 2013 Thank you, il look into it I can't see it being a fault just driver error Cheers! Quote Link to comment Share on other sites More sharing options...
FOCA Posted March 23, 2013 Share Posted March 23, 2013 Thank you, il look into it I can't see it being a fault just driver error Cheers! If the shift light is actually set up/ working but not coming on - it means you are driving it correctly because it will only come on if your not driving it right (revving it too high or letting the revs drop too low/ "labouring" the engine) - unless the new style ones are different Quote Link to comment Share on other sites More sharing options...
Eggy1990 Posted March 23, 2013 Author Share Posted March 23, 2013 Ahh right, suppose that's good then, il keep a eye out for it and rev Abit higher to check Quote Link to comment Share on other sites More sharing options...
Bladerunner Posted March 23, 2013 Share Posted March 23, 2013 Hi, my tdci has a shift light which I almost allways ignore as I feel it comes on at too low a revolution most of the time, just drive it so you don't labour or over rev the engine, you will soon get the feel for the drive and be able to shift gear within the engines torque band. I might be correct and thinking member' INath' turned his indicator light off. Cheers Martin Quote Link to comment Share on other sites More sharing options...
Eggy1990 Posted March 23, 2013 Author Share Posted March 23, 2013 Hi I was just Abit worried it isn't working, I joined the motorway as normal but haven't over revved it as such just suprised I haven't seen it yet I assume in the new models it comes on in between the rev and speedo in the 'hatch' bit Cheers Josh Quote Link to comment Share on other sites More sharing options...
Sliveredge Posted March 23, 2013 Share Posted March 23, 2013 it comes on above the engine temp gauge on the left hand side I'm sure mine pops on around 2.5k rpm to 3k rpm I'll check in a bit and report back Quote Link to comment Share on other sites More sharing options...
Eggy1990 Posted March 23, 2013 Author Share Posted March 23, 2013 Cheers thanks, This snows stopping me getting out init Quote Link to comment Share on other sites More sharing options...
iNath Posted March 23, 2013 Share Posted March 23, 2013 I might be correct and thinking member' INath' turned his indicator light off. Cheers Martin You're correct, got on my nerves coming on at 2k all the time! Quote Link to comment Share on other sites More sharing options...
MartynS Posted March 23, 2013 Share Posted March 23, 2013 It does delay coming on to around 4k when accelerating hard - but if you're doing that why would you change up then? Makes no sense! Quote Link to comment Share on other sites More sharing options...
Preee Posted March 23, 2013 Share Posted March 23, 2013 On my Focus it comes on at 2000 rpm which is crazy and i take no notice of it lol Quote Link to comment Share on other sites More sharing options...
Eggy1990 Posted March 24, 2013 Author Share Posted March 24, 2013 Managed to get out last night in car and revved it enough to get the light on Thanks for the help How's everybody's fuel consumption and mpg going? High as ford suggested Quote Link to comment Share on other sites More sharing options...
Sliveredge Posted March 25, 2013 Share Posted March 25, 2013 I'm hitting 40mpg at the mo and that's just town driving with the odd bit of right foot :) Quote Link to comment Share on other sites More sharing options...
eggy25 Posted March 25, 2013 Share Posted March 25, 2013 I’ve done just short of 80 miles and its climbing all the time to 34.3 at the minute town driving and 1 junction of MW, I’m assuming this will increase after the 1000K mark settling down period I’ve also found my petrol dial goes down quick whilst MPG goes up All in all I reckon I’m going to save more fuel than the 2005 1.4 Zetec I Part exchanged Cheers! Josh Quote Link to comment Share on other sites More sharing options...
Mick78 Posted March 25, 2013 Share Posted March 25, 2013 Don't bother with the change light, flashes to itself 1,500ish miles in and average is sitting at 42mpg, mostly town driving Ford has the 100ps ecoboost as 53mpg for the urban run Quote Link to comment Share on other sites More sharing options...
eggy25 Posted March 25, 2013 Share Posted March 25, 2013 Reckon 53mpg is possible? Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted March 25, 2013 Share Posted March 25, 2013 I'd have said 45 would be more realistic if honest in a petrol. Quote Link to comment Share on other sites More sharing options...
fasty Posted March 25, 2013 Share Posted March 25, 2013 Regarding the MPG - I'm driving gently to and from work, making a token effort to "run in" the engine a bit so not labouring it hard, Approx 50% town driving and 50% motorway (but only up to 70mph for short periods) I'm managing to get around 54mpg combined, which I'm happy enough with. - Steve Quote Link to comment Share on other sites More sharing options...
eggy25 Posted March 25, 2013 Share Posted March 25, 2013 How many miles you done Steve? Just passed my first 100 Josh Quote Link to comment Share on other sites More sharing options...
