dizwod
Minor Scratch
Just a question,
Got a new Focus and have noticed a very very very slight scratch on the drivers door.
Cannot feel the scratch when i touch it its that light.
Whats the best way of sorting this? I dont want to be using anything which removes the paint at all.
I have metallic paint also so not sure if theres any good recommendations to sort this. Not even had this a week yet :(
Pic of scratch attached looks worse in the pic though
lCOXSY7Jy0Ay3TQEbqhZlBJ1LI5UkKDMpXNlEspFlCOXSY7Jy0Ay3TQEbqhZlBJ1LI5UkKDMpXNlEspF
post-41949-0-95030600-1364057917_thumb.j
Try a small buffer on a cordless drill you can pick these up from halfrauds used on mine to sort minor sratches works a treat with the coloured polish or t cut
Agreed a small buff would get rid of that i wet the area with a spray bottle of water when using t cut and buffers just incase you burn the paint easily done did it the first time i used a buffer luckily just a small patch but lesson learned when the old man showed me how i should have done it
I have never buffed anything on a car so a little cautious.
I only every T-cut my older car but that was a state. T-cutting wouldnt damage the paint around the area at all would it?
Use a microfibre cloth wet it then wring it out so its damp dont push down on it just gently rub let the t cut do the work wipe off and check if the marks away then polish wont damage the paint
