d_deridex Posted March 24, 2013 Share Posted March 24, 2013 Hi I haven't posted for quite sometime, I do apologize. I have a 1.6 TDCI 07 reg ford fusion which has done 79k which is rough starting with white smoke and sometimes takes upto ten seconds to fire up but when warm is perfectly smooth and starts on the button. Its not water as its not loosing any or oil as it too is fine, im using normal diesel not supermarket fuel I run it on the motorway at too high a gear to blow out any soot from time to time. I have an android app called Torque connected to a bluetooth obd2 adapter that reads only a stuck clutch switch on its fault log [that has now been fixed, it was a faulty sensor]. Any ideas why its rough running? https://www.dropbox.com/s/hmmnqfp67pvn8n5/IMAG0218.jpg Thanks in advance. Richard Quote Link to comment Share on other sites More sharing options...
Les@ss8 Posted April 14, 2013 Share Posted April 14, 2013 Hello there. It sounds like you have a problem with your glow plugs not working for some reason, ie broken wire, dodgy relay or the glow plugs,( 1 or more ) themselves have packed up. I hope this of some help. Les@ss8. Quote Link to comment Share on other sites More sharing options...
