Leaking injector seals
#1
Posted 19 March 2009 - 08:50 PM
My car's a '04 1.4 TDCi and 6 months after running out of warranty all the seals systematically developed leaks. Since then every year I've had to replace them all. All the works carried out at main dealer, and the car is serviced every 3 months as I do a lot of motorway miles.
#2
Posted 21 March 2009 - 04:28 PM
#3
Posted 07 April 2009 - 07:59 PM
Does anyone here have any experience in having to replace them on a regular basis?
Yes, I had that problem late last year. On an 04 1.4 TDCi, 45000 miles. The independent garage I use said they see it surprisingly often on modern diesels. It cost me nearly £900 to sort out, it is a not a quick job.
I sold the car a week after getting the problem fixed...
#4
Posted 14 April 2009 - 12:38 PM
#5
Posted 01 May 2009 - 08:55 AM
#6
Posted 10 May 2009 - 10:55 PM
#7
Posted 14 May 2009 - 03:52 PM
just had my seals done at the dealers I bought the car from and on following it home about 5 miles there was excessive black smoke coming from the exhaust on accelleration. So I took it back and the dealer who said they would look at it. Phoned the following day and they said there was nothing wrong with it, passed emissions test etc. Took the car about 5 miles on the road again with exactly the same symptom. Back to the dealers again took out the service manager following the car.As the test run they gave the car no one followed so they could not see the smoke! He suggested to run the car as they had cleaned the manifold and it may be the residue from this.....
So have phoned Ford Customer line and they have put me on to another Ford dealer to check out the car so I must wait until Tuesday next week! I have not paid the bill as yet to the first garage but I am expecting it to be posted to me soon
Car has been fine for the last few years done 88k with only 0ne other problem, the fuel pipe routing causing a hole in the plastic pipe where it goes under the air filter housing.
Will keep you posted.
#8
Posted 14 May 2009 - 04:35 PM
just out of curiosity how many miles has the car covered ??
My car's just turned over the 100k mark most of it on motorways at 60mph as that gets me about 75-80mpg
#9
Posted 25 June 2009 - 01:52 PM
I would be interested to know exactly were the injestors are so i could have a look at them, so does anyone know or maybe a photo to look at....
Look forward to hearing from you
#10
Posted 19 August 2009 - 11:32 AM
hi did my boys 52 reg tdci approx 58,000 miles no/s 3/4 cyl seals gone if you are compitant at doingDoes anyone here have any experience in having to replace them on a regular basis?
medium size repairs you can do it your self but you must replace the injector pipes on the injectors seals you replace took me approx 2hrs to fix them.hope this helps you.
#11
Posted 29 August 2009 - 11:25 AM
#12
Posted 24 January 2010 - 05:34 PM
#13
Posted 17 April 2011 - 09:22 PM
thanks aidan
#14
Posted 11 May 2011 - 07:50 AM
In December/January at about 12-14k miles I noticed an exhaust fume type smell and it was missing when you hit 40mph in 4th gear. The garage confirmed that it was the injector seals and did the necessary work - still under warranty (thankfully!).
Now (less than 5 months later, with 20k miles), it has happened again. This time the change seemed to be more sudden, and the smell of diesel is more raw and much stronger. It is also missing occasionally regardless of what speed/gear you are in (usually over 30mph though,not at low speeds).
It is still under warranty, but this surely shouldn't have happened twice within 5 months on a car that has such a low mileage? When I researched the problem it seemed common - on cars with about 40k. And although I do a lot of miles, I wouldn't say it was excessive(still only half the mileage the problem seems common at). I am a very careful driver and don't rev it too much etc. My boyfriend also drives it and sometimes revs it a bit, but he's not as bad as many people.
Anyone got any advice/had a similar problem? And if so, was it fixed in the end/how? Warranty runs out this summer, so I'm just slightly concerned that it will happen again after it runs out.
#15
Posted 29 February 2012 - 11:49 AM
You guys has the ABS module failure yet? If not that's another 700 quidder to look forward to! See previous post below.
ADD ME TO THE GROWING ABS MODULE FAILURE LIST!!!
Hello all,
Had exactly the same problem on my 05 plate fiesta 1.4 TDCI, first the handbrake light came on then shortly after the ABS and engine warning light came on. Car still ran fine.
Booked it into a ford dealer and the usual phone call.
"We need to charge you £99.99 to plug a laptop into you car so it can tell us what's wrong with it. Is it OK to proceed."
"Yes thats great - sounds like a bargain."
Then the phone rings again a bit later to say that it is ABS module failure and itll be almost £700 to fix. I paid up. I got them to leave the faulty part for me to inspect. I believe this part consists of an electical relay box bolted onto a hydraulic component with hydraulc tubes attached. Assumed for £700 they were replacing the whole lot but no - just the electrical box the size of a fist. Someone is having a laugh.
I agree with everyone this is not a wear and tear part as far as I'm concerned. Ford should replace for free. They will lose out in the long run I suspect because they will lose long term customers such as myself.
Be warned - another very common fault in low mileage TDCI's is injector seal failure. Staggeringly similar conversation with the same dealership a year ago or so. Car went in for service running absolutely fine. Mis-diagnosed drop link failure followed by a call to say that the injector seals had failed and one injector needed replacing altogether (on a 5 year old car with low mileage). Again around £700 to fix.
My family and I have had many fords and are long term customers.
This is the last ford I will ever own and anyone asking for my opinion will be told accordingly.
Cheers all.
