xFiestaLoverx
Warning Lights In Fiesta Mk6.5
5 posts in this topic
Hi everyone, a quick question.
When I turn the key two clicks (so electrics turn on) the oil pressure lamp shows up and stays on.
When I actually start the engine, the oil pressure lamp turns off, is it normal for the oil pressure lamp to come on in the way it does for myself?
Yes. Aslong as it all turns off when the ignition starts dont worry. You should regularly check your oil anyway
I did, it was fine, thanks for that.
When you turn the key to the second ignition position im sure the oil and engine management lights stay on
Ive just checked the lights that stay on are the Engine management light, oil light, battery and obv handbrake light
