AJ_sXe Posted April 3, 2013 Share Posted April 3, 2013 Ok, so I bought a set of heated Mist-type front washers, I assumed that my Ford ones were already heated seeing as I have a Titanium (yes I know foolish of me to assume).My question is: can I fit these ones in such a way as the heating wires/element is shielded while not in use or should I just buy a set of unheated ones and flog these? Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 3, 2013 Share Posted April 3, 2013 You can just cut the wires off if that's what your meaning? Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted April 3, 2013 Share Posted April 3, 2013 I have heated ones, I put he loom in for them, but I had them about 8 or 9 months before this just hanging there :P they're fine. Quote Link to comment Share on other sites More sharing options...
AJ_sXe Posted April 3, 2013 Author Share Posted April 3, 2013 I have heated ones, I put he loom in for them, but I had them about 8 or 9 months before this just hanging there :P they're fine. A: Is the loom easy to find/source? (is it already there?) B: Is it easy to fit/wire? You can just cut the wires off if that's what your meaning? I could just do that, but was thinking about taping up/covering them to stop the plug rattling/vibrating. Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted April 3, 2013 Share Posted April 3, 2013 A: Is the loom easy to find/source? (is it already there?) B: Is it easy to fit/wire? Nope it's a bar stool to source, I was lucky and one came in at the breakers. It's a case of ring around I guess, but not sure if most keep it on the main loom. Yep, just splice in to the heated screen bits and you're away. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 3, 2013 Share Posted April 3, 2013 Mine were heated ones because strangely I found them for less than non heated ones. Snipped the wires off and no dramas. Quote Link to comment Share on other sites More sharing options...
