ROTHERS Posted March 20, 2009 Share Posted March 20, 2009 Hello Took my daughters car for an MOT 2 weeks ago, it came back with a clutch problem, it was a real challenge to get it into gear. Took it back, they bled it and its been fine until today ( I checked the fluid level every other day). Its a problem again engaging a gear but the fluid looks fine. Can anyone confirm that the clutch will probably need replacing ? Any insight/thoughts most welcome. Cheers Craig Quote Link to comment Share on other sites More sharing options...
delboy Posted March 22, 2009 Share Posted March 22, 2009 HelloTook my daughters car for an MOT 2 weeks ago, it came back with a clutch problem, it was a real challenge to get it into gear. Took it back, they bled it and its been fine until today ( I checked the fluid level every other day). Its a problem again engaging a gear but the fluid looks fine. Can anyone confirm that the clutch will probably need replacing ? Any insight/thoughts most welcome. Cheers Craig sounds like the thrust bearing has gone in the clutch get a new clutch & bearing fittet m8 sounds like the problem to me look here for the parts www.buypartsby.co.uk or www.fordpartsuk.com check them for prices & ask for the thrust bearing aswell incase they only price for the clutch & get the p&p & vat inc aswell then phone your local garage (non fords) & ask for a clutch & thrust bearing supplied & fitted price then as what it would cost if you supplied it all they don't like it so much if you supply as they say about warranty etc ...load of crap asthen loose out on the mark up of the goods. that's what i do so be prepared or do it your self as it's not that big a job m8 i done my ford galaxy one & that's a big one & saved myself about £400 Quote Link to comment Share on other sites More sharing options...
