frogster_ Posted April 4, 2013 Share Posted April 4, 2013 I've recently bought my 04 plate Fusion 3 1.6 (manual). Occasionally when starting off - either putting it into 1st gear or reverse - the gear just wont engage, until after re-shifting twice and thrice! This has happened at some very embarrasing times. Not only is it embarrasing, but potentially hazarous with the risk of rolling backward!! I've been told by people with Mondeos that they have this problem & is generally resolved by shifting through the gears to 'realign' them, so to speak. The car was only recently serviced and MOT'd and runs brilliantly apart from this. If anyone has / previously had this problem and could shed any more light then any advice would be greatly appreciated. Many thanks!! Quote Link to comment Share on other sites More sharing options...
amigadude Posted April 5, 2013 Share Posted April 5, 2013 I sometimes have problems shifting into reverse (feels like it's in but you just get gear grind when you let the clutch up) but on Wednesday when I was leaving MOT centre (just needed a tyre and a backbox :) ) I reversed out and couldn't get 1st to play ball at all, tried a few times then shifted back to reverse, backed up a bit, then tried 1st and it worked this time. Sorry I can't help with a solution, not had the problem before or since, I will probably leave it unless it starts doing as often as the reverse problem. Quote Link to comment Share on other sites More sharing options...
