Fiesta Mk 6 Remote Central Locking Please Someone Help
fiesta0207
Omg lol. Maybe then if it is that high ill have to live with them :) lol been using the car 4 3 days np with it so clearly just electronics x)
That was a ford dealer remember..... I'm sure your friend of a friend could add a decimal point in to that price:-)
Now that looks like an awesome piece of kit (if it does what it says on the tin), it will make interesting reading when I get the chance, any idea how much they cost?
Asked him iff it works for a fiesta and then ill ask him if he got anyones already modified. Otherwise around £9.59 then you have to modify it to make it a writer
Actually the program seems ok to operate quick to do and you can back up settings too.
If it does as its told then that is a well spent £9.59 then drive by your nearest dealership sticking your fingers up at them lol
Well actually i would not do that cause they are the only guys who I trust to fix my car. I had someone fix my injector seals and he killed my injectors... Had to have them do the repairs... From then on I dont trust anyone as usual services oil change etc i do myself
Was just meaning that they have a bad reputation (all dealers not just ford) for their astronomical repair bills
Yes piece of mind is always key, but I have found a brilliant independant garage with huge savings over dealer repair cost,they are very professional and trustworthy, they did my timing belt on my old car and a fraction of the cost.
Anyway back to your topic.... Has your headlight switch arrived yet? Would be cool if that fixed all the electronic issues on your car:-)
Lucky you!! Lol
Nope no switch yet... Now I am doubting that it is from the switch anyway. Cause the click is the same as to when it gives the signal to move the wiper even the old gem used to do this click.
Hope that guy tells me that the programing can be done using the elm lol
I still think it could be the switch because if the GEM tries to override the switch(like you said earlier) then fitting the ont that the GEM actually is programmed to then that should be the jackpot? I could be wrong(hope I'm not)
If I am then I would contact the programmer guy and hope he can sort it then worst case scenario a trip to your local ford dealer with a heavy wallet :-)
Yes your reasoning make sense :) hope i dont need to overload my wallet lol
The switch did not arrive yet :(((
Actually though I dont have other issues.
Just a small question what are the main differneces bbetwwen the fiesta and the fusion?
I'm not at home either but will translate it once I get I to my computer.
Tbh I'm not 100% sure if all the differences between the fusion and the fiesta, I think they are essentially the same car, using the same chassis and a lot of the same components and parts.... I'm pretty sure I have seen parts(even the GEM) listed on eBay as for fiesta/fusion.
I wouldn't like to say so for sure, but I think its be worth a try?
Still not had the chance to translate that link you sent but I will as soon as poss and I'll let you know what I think.
Yeh i will have access to a pc tomorrow so i cant do it tonight. Unfortunetly though this will probably work on the facelift only i think
My conclusion to why there are 3 types if GEMS (1st 4 letters)
2s6t for cars with only 1 CAN
4s6t for pre facelift with 2 CAN
6s6t for facelift with 2 CAN
"In vehicles built from MY 2003.75, an additional second CAN bus system is used depending upon vehicle model."
Hence why 2 GEMs for the prefacelift
Think your knowledge has surpassed mine lol, do you know what the 2 CAN bus system on the pre facelift has that the 1 CAN doesn't?
Also how did you work out that the 2CAN was introduced In the 3rd quarter of 2003? When I was upgrading mine I was told(or I read somewhere) that ford did change the GEM in that year and they weren't compatible with the later pre facelift.
Feature wise I think they are same. Just the speed at which they communicate as in 2s6t on the HScan (since only 1 i am assuming it is an HS) while the 4s6t communicates on the MScan
For details on the electronics see
http://ford.workshop-manuals.com/Fiesta_2002.25_11.2001/index.php?id=1068
For details on the GEM see
http://ford.workshop-manuals.com/Fiesta_2002.25_11.2001/index.php?id=1112
I managed to translate the GEM part of the program from russion and it currently looks like this.
Центральный замок
Управление ЦЗ с ДУ
0ткрывание багажника с ДЧ
0ткрывание багажника при
вкл эажиегании
0ткрываь багажника двойным
нажатием ДЧ
Кнопка багажника в салоне
Запрет отпирания ЦЗ из
салона
Central locking
Managing Remote Power Door
Locks
0tkryvanie boot to a TM
0tkryvanie boot at startup
eazhieganii
0tkryva trunk by
double-clicking DF
Button inside the trunk
The prohibition of the release
of CH salon
Концевики
Концевик капота
Концевики дверей НР типа
Концевики задних дверей
Праворульный авто
Концевики багажника
Концевики багажника НР
типа
limit switches
the engine hood
HP-type door switch
Limit switches back doors
RHD cars
trunk switch
HP trunk switch type
Опции
Опция датчик цожця / света
Опция -
подогрев заднего стекла/зеркал
Опция - складные
зеркала
Опция - обогрев лобового стекла
Опция - климат контроль
Кнопка складывания зеркал
в салоне
Автоматическое включение
фар
Настройка через ВК (Запрет
щаманства)
Наличие заднего дворника
options
Option tsozhtsya sensor /
light
Option - heated rear window /
mirror
The - folding mirrors
The - heated windshield
Option - Climate control
Button folding mirrors in the
salon
Auto-On Headlights
Setting up a VC (Prohibition
schamanstva)
Having a rear wiper
Фишки и прелести
Махать дворниками при омывании
Дополнительный взмах дворников
Выстрые замки (отменяет хитрые замки)
Дожиматв замки, если были открыты двери
Зацний дворник при задней передаче
Колесико регулировки прер. режи. дрворн.
Chips and charms
Wipers when wash cycle swing
Additional wipers sweep
Rds locks (disables tricky
locks)
Dozhimatv locks if the doors
were opened
Zatsny wiper when rear
transmission
Click Wheel prairie. mode.
drvorn.
Настройки изменяемые с ВК
Запирание при начале движения
Вкл аварийку при экстрениом
торможении
Три вспышки поворотов при перестроении
Пошаговое отпирание ЦЗ с ДУ
Складывание Зеркал при Запирании
Посадочные огни
The settings are changed with
VC
Locking when the beginning of
the movement
On emergency gang emergency
braking
Three flash of turns when you
rebuild
Step by step unlocking Remote
Power Door Locks
Folding Mirrors when locking
landing lights
Непроверенное
Длинный импульс хлыста или
хитрые замки
untried
Long pulse whip or clever
locks
Somethings I still can't understand what I do. The program can get your asbuilt data so you would know what you have and what you dont installed.
Have you made any progress with your programming of the GEM? Or fitted your new headlight switch?
Nope :(. Switch arrived just found no time to change it yet but should do it this weekend. Elm cable still on the way and am still translating the program... Will keep you posted
