George Lawrence Posted April 6, 2013 Share Posted April 6, 2013 Morning all, I got the socket with the window for removing the injectors as suggested. After removing the fuel lines etc the socket will not drop down over the injector completely. Do I have to remove the top half ie where the lines attach ? your help will be greatfully received. Cheers George Quote Link to comment Share on other sites More sharing options...
fish 10 Posted April 6, 2013 Share Posted April 6, 2013 i had to remove all lines,wireing,pull out the injector seals in top of rocker cover,and then i removed rocker cover for easy access,as you need alignment tool to put them back in,quiet an easy job once you get the rocker cover off,hope this helps Quote Link to comment Share on other sites More sharing options...
