Engine Light
Mariedc
 Share
Hi Guys. I am a maiden in need of some assistance. My oil light came on last friday and I topped up my Focus C Max 1.8 petrol with 10W40 oil without checking to handbook first. I now know it should have been 5W30. My engine light came on yesterday after a busy weekend (drove over 400 miles). I hoped it would be okay this morning but it is still on. The car is running fine at the moment (touching wood as i type). Any ideas that aren't going to cost me a fortune ??
Link to comment
Hello Marie and welcome to the forums.
First off all, the oil you put in is the wrong grade as you pointed out but to be honest i cant see it having an immediate negative effect. Although i would get it changed as soon as possible.
As for the engine management light, you really need to get the code(s) read to point you in the right direction of a fault - if there is one.
Does the car appear to run ok?
Link to comment
Hi Stef and thanks for your response.
The car seems to be running fine as it always has. How do i get the codes read to find out if there is a fault. (sorry if this sounds like a adumb question but i have never had anything like this wrong with a car before)
Link to comment
Any local garage will be able to do it. What they should do is read any codes and make note of them and then clear them and see if they return - certainly what i would do if the car is running fine.
  • Like 1
Link to comment
If you have a trip computer as I do, you can use this trick:
http://www.fordownersclub.com/forums/topic/1486-focus-dashboard-secret-trick/page-3?hl=%2Bdash+%2Btrick#entry72056
if there are any error codes you will see them there, post them and we may be able to advise.
  • Like 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
