Sassygirl Posted April 10, 2013 Share Posted April 10, 2013 Rang to find out how much my brake disks were going to cost and i was told there are two sizes listed for my car. So without having to go outside in the cold, could somebody please tell me what size mine might be :) She's a 2007 LX model :) Many thanks p.s should i change the brake pads at the same time? Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 10, 2013 Share Posted April 10, 2013 What engine do you have? And yes you must change the pads too Quote Link to comment Share on other sites More sharing options...
Sassygirl Posted April 10, 2013 Author Share Posted April 10, 2013 Its a 1.6 tdci :) Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 10, 2013 Share Posted April 10, 2013 I think the 1.6tdci uses the smaller 278mm. Both the 278 and 300mm discs use the same pads though Quote Link to comment Share on other sites More sharing options...
Foci_st3 Posted April 10, 2013 Share Posted April 10, 2013 Weren't the 300mm on the st Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 10, 2013 Share Posted April 10, 2013 Weren't the 300mm on the st 320mm on the ST IIRC. As they are used as an upgrade on the Mondeo - unfortunately don't fit inside my 16" wheels There are a few models that use the 300mm including the 1.8 tdci Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 11, 2013 Share Posted April 11, 2013 even mine were confusing so many choices i did have it written down and lost it doh......so back to taking the wheel off and measuring again grrrr Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 11, 2013 Share Posted April 11, 2013 Shouldn't be any need to measure, any I have done its been stamped on the caliper Quote Link to comment Share on other sites More sharing options...
Sassygirl Posted April 11, 2013 Author Share Posted April 11, 2013 so the smaller ones should be fine to use? :) The price difference is £30 for smaller ones each, £45 for larger ones Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 11, 2013 Share Posted April 11, 2013 Maybe is stef cant see it for looking at it to be honest ill look again later Quote Link to comment Share on other sites More sharing options...
Foci_st3 Posted April 11, 2013 Share Posted April 11, 2013 so the smaller ones should be fine to use? :) The price difference is £30 for smaller ones each, £45 for larger ones You will need the same size that's already on there. Quote Link to comment Share on other sites More sharing options...
