DanGersFord Posted April 15, 2013 Share Posted April 15, 2013 Have you done a few modifications to your car? Or gone all out and made a load of modifications? Why not start your own build thread in the NEW Ford Projects and Builds section ( http://www.fordownersclub.com/forums/forum/89-ford-projects-and-builds/?prune_day=100&sort_by=Z-A&sort_key=last_post&topicfilter=all ) and show off your motor and what you've done to your pride and joy :) maybe even get some inspiration on what to do next from looking at other peoples threads :). OR If you just want to discuss something to do with modifying why not post it in the NEW dedicated Modification Discussions section http://www.fordownersclub.com/forums/forum/90-ford-modification-discussions/ Enjoy FOC :) 4 Quote Link to comment Share on other sites More sharing options...
Oliverb Posted May 26, 2013 Share Posted May 26, 2013 My thread, mod process. Comments welcome.. http://www.fordownersclub.com/forums/topic/44111-my-focus-titanium-3/?p=263055 2 Quote Link to comment Share on other sites More sharing options...
19dayday91 Posted February 17, 2014 Share Posted February 17, 2014 Has anyone fitted a omex launch control to the mk1 1.6? If so do I use the same ecu wires as the fiesta zetec s? Thanks.in advance :-) 1 Quote Link to comment Share on other sites More sharing options...
Jager King Posted June 29, 2014 Share Posted June 29, 2014 My build thread on the focus page needs moving now :) 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 29, 2014 Share Posted June 29, 2014 drop me the link to what you want moving and I will pop it over to the builds section for you. Quote Link to comment Share on other sites More sharing options...
zoltann Posted September 21, 2014 Share Posted September 21, 2014 Hi guys, i want to buy a bluetooth kit for my focus and i saw this. What's your opinion? Anyone has it? Does it worth it? http://www.amazon.com/Kinivo-BTC450-Bluetooth-Hands-Free-Input/dp/B009NLTW60/ref=cm_cr_pr_product_top Quote Link to comment Share on other sites More sharing options...
layney83 Posted October 7, 2014 Share Posted October 7, 2014 What can I do to make my focus zetec fast ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
layney83 Posted October 7, 2014 Share Posted October 7, 2014 Faster Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 1, 2015 Share Posted January 1, 2015 Is there a way to make the bonnet release on a Focus a SENSIBLE one with a pull under the dash, rather than the "AARRGGHHHHH!!!!" inducing Ignition Key one? 3 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 2, 2015 Share Posted January 2, 2015 I was looking into this on the cmax but had to get rid of the car in the end. It is possible but requires a fair amount of work. You can remove the bonnet lock assembly and replace it with one from a car like a fusion or mondeo, it would then need to be welded on in the right place.ypu then need to make a hole through the firewall and feed a release cable and it's sheath through there and attack it to the primary release on the bonnet catch, and then fit an internal release on the inside, you might need to weld this on the inside or bolt it onto place. You will need to adjust the length of the cable and test it. It is doable but not the easiest to accomplish but would be well worth it. Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 2, 2015 Share Posted January 2, 2015 Hmm.... Or I suppose there the option of just throwning the whole damned thing away and using locking bonnet pins. ;) Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 2, 2015 Share Posted January 2, 2015 I also explored that option :-D 1 Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 2, 2015 Share Posted January 2, 2015 I also explored that option :-D Anything come of it? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 2, 2015 Share Posted January 2, 2015 I was tossing and turning but favouring the new release mechanism. Bonnet pins would definitely have worked, but it's best to get the flat handle style with keys to unlock as a protruding pin could be an mot failure. My car was crashed into and exchanged a short while before I started the conversion. Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 2, 2015 Share Posted January 2, 2015 Yeah, I was looking for SVA approved ones, and the flat ones with handles look the best. meanwhile I have to get the *four letter word alluding to a lady's front bottom* to open on the key, and the key won't even *four letter word alluding to 2 people doing something very intimate* TURN!! *Word alluding to Child born out of wedlock*! *sigh* 3 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 2, 2015 Share Posted January 2, 2015 Haha loving the substitutes lol. Press down above the catch at the same time and you should stand the best chance Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 2, 2015 Share Posted January 2, 2015 I've tried that, too. I fear the Angle Grinder option will be the only way forward, because as useful as the "How To" is in the Guides section it doesn't seem to apply to the Mk1, which has a box around the back of the lock mechanism. There's a Youtube vid of someone just drilling the son of a *word meaning Canine Female* out, but I'm not sure how far to drill!! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 2, 2015 Share Posted January 2, 2015 It could be cheaper to take it to ford, otherwise you will have to replace the bonnet. On a plus side, you would have a bonnet to practice drilling through for the pins lol 1 Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 2, 2015 Share Posted January 2, 2015 I KNEW I should have kept my old Mercedes 190E! That was almost indestructable!! :( Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 2, 2015 Share Posted January 2, 2015 Sadly the focus weak point is the lock, ford will charge about 300 to fix.... Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 2, 2015 Share Posted January 2, 2015 Yeah, no wonder the f**king things are so "Combustable" :/ Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 2, 2015 Share Posted January 2, 2015 I would get ford to do it if your going for replacement, but if your going to do yourself the job, I would definitely look for the replacement though, depending how long you want to keep the car. Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 2, 2015 Share Posted January 2, 2015 Given that the car was only 200 quid I think lobbing out 150% of purchase price just for the bonnet release is a teeny bit OTT. The guy opened the bonnet before I drove it away, so I KNOW the *Word meaning child born out of wedlock* WORKS! :( *sulk* Do I REALLY need to resort to THIS?? 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 2, 2015 Share Posted January 2, 2015 I think if you spent that little on it, it's worth beating it! Even if you destroy and disintegrate it, you can then put the pin setup on it. Quote Link to comment Share on other sites More sharing options...
KlingKlangMan Posted January 2, 2015 Share Posted January 2, 2015 I'm open to offers of help. Quote Link to comment Share on other sites More sharing options...
