jlb141289 Posted April 17, 2013 Share Posted April 17, 2013 hi everyone, im a new member so not completely sure how the site works yet so bear with me. I've recently bought a 2002 reg mk1 focus and when i bought it the engine oil light was illunminated, naturally i checked the oil level and it was low so i topped it up and the light went out. after driving it for a couple of days the light came back on and made me think there might possibly be an oil leak, however, after giving the car a good look over i cant find anything and the oil level is actually between the min and max levels on the dipstick so im a little lost as to what could be wrong. I did think it might be beacuse the oil is the wrong type but after double checking in the manual i have used the correct type. does anyone have any ideas what the problem might be? sorry about the long essay thanks jason Quote Link to comment Share on other sites More sharing options...
Mike77 Posted April 18, 2013 Share Posted April 18, 2013 Sounds like the oil switch, this is the sensor that detects when the oil is low and puts the light on, it could be faulty. This would be the first port of call for me. Not sure were it is located on your car though. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 18, 2013 Share Posted April 18, 2013 The oil pressure warning switch is mounted flywheel end of the engine by the vacuum pump. To make it easier to get to the switch you may need to partially disassemble the air cleaner inlet duct, hoses and crankcase ventilation system oil separator from the left hand side of the cylinder head. Unplug the cables and unscrew the switch, some oil may leak out. On refitting use a suitable thread sealant on the switch and tighten to 21 ft. lbs.(29 Nm) with a torque wrench. Quote Link to comment Share on other sites More sharing options...
jlb141289 Posted April 18, 2013 Author Share Posted April 18, 2013 thanks for the replies, has helped a lot especially with the picture, i have a haynes manual myself which ive been flicking through to try and discover what it might have been, but ive been unsuccessful so far. Hopefully i will be able to rectify soon cheers Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 18, 2013 Share Posted April 18, 2013 Here's hoping its just the sensor playing up and not the first sign of the oil pump failing. Quote Link to comment Share on other sites More sharing options...
