wb78
Does It Matter If Windows Don't Go All The Way Up With A Wind Deflector?
15 posts in this topic
I have just fitted some wind deflectors to my car and I am just wondering if it matters that my window is about 3mm lower than it should be?
Nah mate it wont make any difference
Thank god for that. I have been messing on with them for ages trying to get it all the way up
Well there will be about 3mm of plastic that wasn't there before ;)
Btw you may need to reset one touch up/down if if stops working.
The one touch up and down only works on the drivers side window anyway? Is that right?
Yeah that's right. They're always a little lower, but they're fine. I've had wind deflectors for 18 months and not a problem, just switched them to the new car and again, no problem.
Give them a quick squirt in the channels with WD40 and the window will find its own way.
Think I ended doing WD40 on my last car because 1 channel was a pain >.<
Thanks guys
Just force it shut if needs be and leave them closed for 3 days and they'll bed in lovely. I had really bad trouble with one window jamming at first but over time they sort themselves out :)
Mine go up and stay up and don't jam so I am just going to leave them how they are.
Sometimes on mine sound like grit on them when closin horrible noise x
Same on mine, tbh I'd say it probably is grit/road grime/general kak.
Ends up scratching the tops of the windows, keep them channels clean :P
I just out on a new set on my car yesterday. The window sits lower than it should for a while but it'll gradually go most of the way up as the deflectors settle in.
