paulbh
Reversing Lights
Hi all i was wondering if anyone could help me the reversing lights on my mk3 51 mondeo lx 2.0 petrol i've tried the obvious fuses bulbs but still not working Thanks Paul
it could be a faulty reverse switch which i screwed into gearbox
+1 on the faulty reverse switch, it is a common fault.
If you want to test it. turn the ignition on then take the connector off the top of the switch, join the two wire ends wire a bit of spare wire to make a connection and if the reversing lights come on the switch is the problem
