Guide - 2013 Mk 7.5 (Facelift) Fiesta Zetec S Front Grill Install
Willy
All parts can be obtained from your Ford dealer or at the following sites. Prices vary so shop around for the best deal.
http://www.european-...6bnkglo41ifdnt7
Black Front Grille Set - KITFIETRIM18 - £198
http://www.fordpartsuk.com/shop/ford_fiesta_sporty_grille_kit_from_2012_to_2014_f_KITFIETRIM18.htm
Black Upper grille - 1778260 - £70:80
http://www.fordpartsuk.com/shop/ford_fiesta_front_upper_grille_2012_f_1778260.htm1 (7).jpg
Black Lower grille - 1801358 - £79.95
http://www.fordpartsuk.com/shop/ford_fiesta_front_lower_bumper_grille_2012_f_1801358.htm1.jpg
Red Upper Grille Set - KITFIETRIM21 - £148
http://www.fordpartsuk.com/shop/ford_fiesta_grille_upgrade_kit__f_KITFIETRIM21.htm1 (1).jpg
Red Upper Grille - 1865992 - £67.15
http://www.fordpartsuk.com/shop/ford_fiesta_upper_grille_with_red_frame_2014_f_1865992.htm1 (3).jpg
Red Lower Grille - 1884342 - £80.50
http://www.fordpartsuk.com/shop/ford_fiesta_zetecs_lower_grille_with_red_frame_2014_f_1884342.htm1 (4).jpg
O/S or D/S Fog Surround - 1777210 - £18.75
http://www.fordpartsuk.com/shop/ford_fiesta_rh_fog_lamp_bezel_2012_f_1777210.htm1 (6).jpg
N/S or P/S Fog Surround - 1777211 - £18.75
http://www.fordpartsuk.com/shop/ford_fiesta_front_fog_lamp_bezel_lh_2012_f_1777211.htm1 (5).jpg
Air Deflector / Spoiler - 1801362 - £39.99
http://www.fordpartsuk.com/shop/ford_fiesta_front_bumper_aero_foil_black_f_1801362_c_1101.htm
Rivets - 1555829 - £3.00 for 12
http://www.fordpartsuk.com/shop/ford_fiesta_front_bumper_skirt_fitting_kit_from_2012_onwards_f_1802987.htm1.jpg
Here's the fitting guide.....................
When fitting the grilles fit the lower grille FIRST!!
Fitting the lower grille first will ensure a good tight fit before fitting the upper / larger grille.
If your thinking of removing the bumper then this guide will definitely help. http://www.mountune.com/downloads/Fiesta_ST_IC_install_rev1.0.pdf
Fog Surrounds first
Quite an easy job here which will take you only a few minutes to complete.
First thing to do is remove the old surrounds, it's easier if you take the chrome piece off first and grab in the same area and pull (quite hard) until you can get your other hand under the edge to  gentle pull it off.
That's the hardest bit done, you now should have something like this.
Give the exposed area a quick clean then get your nice new surround, Line up the tabs and the slots and push it home, you are now done.
Front Grille .........
Ok this one isn't as easy as expected and be prepared to get sore hands.
There's a few ways to do this. A trim tool will come in handy. Use the tool to pry off the chrome  trim first. Place the tool on the inside of the trim and gently remove.
Once the chrome trim is off, use the trim tool to release the clips holding the grille on. Give the grille a gentle tug and that should release it from the car.
The other option is to pull the grille from the car starting from one of the corners. Once started gently but firmly pull the rest of the grille from the car. Be warned the grille can break so be prepared.
To avoid any breakages I recommend removing the front bumper using Mountunes guide here. http://www.mountune.com/downloads/Fiesta_ST_IC_install_rev1.0.pdf or using a trim tool.
Next you'll need line your new grille with the slots on the bumper and push them home until you've gone all the way round. You should now have very sore hands but be admiring your hard work.
The lower grille is a very similar fitting
Lower Grill ..........
As the upper grill really, start by pulling off the grill, clean the area before placing your new grill into the empty space.
Push the new grill home and your done
Front Spoiler next ...............
Start by removing the black rivets from under neath the front bumper, there will be 8 to remove and will require you jacking up the front of the car so that you can get good access with your drill.
Once removed you'll need to fish out the old pot rivets. this is a pain but be patient.Next you'll need your new spoiler and rivets.
Place the spoiler in the locating holes under the bumper, insert a rivet where the old ones were, and pop away until all 8 are done and the spoiler is firmly in place.
Your all done and should now be loving the Zetec S look.
First thing to do is pull the Grille from the car starting from one of the corners. Once started gently but firmly pull the rest of the grille from the car. Be warned the grille can break so be prepared.
post-5052-0-09306900-1366561595_thumb.jp
post-5052-0-51933400-1366578812_thumb.jp
The lower grille is a very similar fitting :)
post-5052-0-76862300-1366749204_thumb.jp
post-5052-0-71858000-1366749215_thumb.jp
Push the new grill home and your done :)
post-5052-0-67053100-1366749259_thumb.jp
post-5052-0-68366900-1366749383_thumb.jp
post-5052-0-77269400-1366759827_thumb.jp
post-5052-0-54525900-1366749493_thumb.jp
post-5052-0-02691900-1366749638_thumb.jp
Your all done :) and should now be loving the Zetec S look.
post-5052-0-73842000-1366749744_thumb.jp
  • Like 3
Nice guide Willy.
Out of interest does that spoiler lip fit the MK7?
Nice guide Willy.
I know there different shape but can't see why not.
Sizes approximate.
post-5052-0-80053200-1366760081_thumb.jp
Thanks might consider this.I really want the Mountune carbon one but at £150 its a bit pricey and if I scraped it on a kerb I'd die.
  • 3 weeks later...
What a great guide willy! I'm looking to upgrade my front grill on my zetec as I really like the zetec S look! wheres the best place to get those parts? Ford dealer? or is there a website that manufactures them?
cheers
Marc.
Thanks for the info, what would be price difference between the parts man and the European webpage?
Cheers
MarcoZetec13
Depends how well you get on with them I guess but around 10% off
  • 1 month later...
Anyone have the Finis code for the bumper itself?
Cheers
  • 6 months later...
  • 1 month later...
Hi There
I have just ordered a 2014 titanium with 17 inch alloys and full dress up kit in black. I want to put a honeycomb grille on the front and came across your thread. Do you know where i would be able to buy the grille from and do you think a garage would do it for me (being a girl!). Also as its a finance car, i would need to put the old grille back on, is this possible?
All the info you need is in the first post Kia.
I would say order your grille and get your ford dealer to fit it. Your looking at 1 hours labour charge to do the work. Options should be ok as long as you use ford parts. If your not sure ask your dealer for more info.
I got all my parts from my local ford dealer. It took a few days to get all the parts with the exception of the main grill which came from Germany and took a week.
Hi Willy,
Great guide, just bought the parts from my Ford dealer and plan to install soon, and will very much use your guide for this.
I love the honeycomb grill.
Cheers from Denmark.
Sent from my Nexus 5 using Ford OC mobile app
Hi Willy,
How long did it take you? Thinking about doing it today after work :)
Thanks,
/Mick
Mick give yourself an hour for the main grille and lower grille, 30 minutes for the fog surrounds and 2 hours for the lower spoiler / splitter.
Thank you for the info Willy :-)
Just finished, I am missing the lower spoiler, it will get done when I can get a hold of a lift :-) thanks for advice Willy!
New honeycomb front
  • 3 weeks later...
Hi, could you please link me to the exact ones you ordered? Been looking on the net and it's hard to find, and can't find any at the prices you've stated, thanks
Hey.
Www.europeanparts.net
Check out fiesta MK7.5 and you'll find the parts there, sent from Germany but good quality Ford parts.
Cheers
MarcoZetec13
Sent from my LG-D802 using Ford OC mobile app
