Coventryadz
Starting Problems Key Or Barrel Ford Mondeo 2001 Tddi
Hello I have had my mondeo for 3 months now used to start 1st time ever time but has started to play up I think it maybe the key warn out or the barrel I need to play about with the key to start the car. Wot do you think guys ???
is the key edges worn i expect thats the prob if so you need the key no or if you havent got that you might have to take out the door barrel and get ford to read nos of the plates.mine was so far gone the numbers they cut the key to was way out.but they said if i take out door barrel they will get the nos of that hope this helps
Cheers mate thts wot I thought my key quite warn out so thts probably it were would I find the key number out ? And how much ruffly cheers
if you have a book pack you might have a sticker in there if not then its off to ford they might have it on there system but more than likely its going to be strip barrel out.unless u got a spare.i paid £5 for mine from ford cut to key no after removeing door lock and barrel
I'm Assuming your key is similar to this
post-41018-0-58526500-1366668889_thumb.j
If so then you will only need the horseshoe section, which are available from ebay, then have that cut for your car and change it for the worn one
Yes tht the key mate and cheers for the help gonna pop to my local ford garrage and get a price for the key and only a £5 not bad from ford realy
