Breadas Posted April 24, 2013 Share Posted April 24, 2013 Hi all. I was driving home from work, short 3-4 mile drive. Had the heating on and realised that it wasn't heating up. The. I noticed the temp gauge on the dash rising near to red, then in red, then what I assume is a engine overheat light come on ( an ! in a jagged circle). Then the seat belt light came on (only me in car wearing seat belt). Then the revs started to drop and it felt heavy to drive, like a power loss of some sort and loud fan noises from under the hood. When I stopped to reverse park the car was juddering, likely I was so close to home I guess. Being so late I can't see anything to look at the car/under hood. Just wondering if any of to lovely people have heard of something like this and have any pointers a novice like me can look at?!.... Much appriceated for any help Gav Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 24, 2013 Share Posted April 24, 2013 Sounds like the car's gone into limp mode because its over heated. Thats why its so heavy to drive etc its a function to stop further damage being done to the car. Check you coolant/antifreeze level in the morning make sure its not too full or low etc also the colour of it if its like a rusty red colour it could be a blockage in the cooling system. Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 24, 2013 Share Posted April 24, 2013 Id presonallh get it into a garage for someone to take a look at it either way tomorrow if possible Quote Link to comment Share on other sites More sharing options...
Breadas Posted April 25, 2013 Author Share Posted April 25, 2013 I did check the liquid sat just gone and when filling screen wash a bit spilt, would that cause harm?! (4days...) I will try to have a look under hood tomorrow but will probably have to leave a detailed look until weekend due to work :/ Quote Link to comment Share on other sites More sharing options...
Breadas Posted April 25, 2013 Author Share Posted April 25, 2013 Thanks again... Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 25, 2013 Share Posted April 25, 2013 To me it sounds like a thermostat problem. Quote Link to comment Share on other sites More sharing options...
Breadas Posted April 25, 2013 Author Share Posted April 25, 2013 Hi all. I have put some anti freeze in, checked under car and got to see it pouring on the ground :/ Having looked under the hood it seems to be leaking at the thermostat so hopefully that is the problem... Thanks again and I will post what solution I get. Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 25, 2013 Share Posted April 25, 2013 Sounds like that could be your problem maybe find theres a split somewhere and its over heated because of not having enough coolant/antifreeze Quote Link to comment Share on other sites More sharing options...
Breadas Posted April 25, 2013 Author Share Posted April 25, 2013 Yea it does make sense. It must have happened recent cause the fluids were fine Saturday... Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 25, 2013 Share Posted April 25, 2013 Moving this to the focus section Quote Link to comment Share on other sites More sharing options...
Breadas Posted April 27, 2013 Author Share Posted April 27, 2013 Turns out thermostat housing is cracked and the seal is knackered. Just waiting replacement parts. Thanks again :) Quote Link to comment Share on other sites More sharing options...
soulman123 Posted April 27, 2013 Share Posted April 27, 2013 Quite a common problem. At least its a job you can do at home. When my mates went he changed the thermostat as well for good measure, nothing wrong with his old one but while it was off and coolant out an extra tenner might be worth doing. Quote Link to comment Share on other sites More sharing options...
