AdBlock Warning
martinstone
Mondeo Tdci Injectors Question
4 posts in this topic
hello, the injectors supplied to me are code 301z the ones removed were 501z am i correct in thinking the nozzles are too long and wont work on my car? or is there away around this? my pump failed and as everyone says replace injectors also but is there anyway my injectors could be saved as they were only replaced months before at a expensive cost, no metal shards were found anywere in the fuel system could i have been lucky?
If it were me I would risk using the old ones. You might as well chance your luck and save the cash.
have you had the old 1's tested??
If there were no filings you should be ok but when a pump goes usually you replace the tank fuel lines and injectors but you might be lucky
