glennkelly
Knocking And Vibration After Clutch And Dmf Replacement
Hi
I have just had my clutch and Dual Mass Fly Wheel (DMF) replaced on my 2005 (late 55 facelift) 1.8 TDCI
Since picking it up I get a Knocking noise when releasing clutch in any gear. Sound comes from near side of the car.
I am also getting a Vibration through clutch.
Any suggestions?
More history.
When they replaced the clutch they found they had the wrong DMF.
Refitted everything then took apart again to fit clutch and DMF.
When it came to re doing the clutch and flywheel the DMF was not fitted
correctly, resulting in the car dropping power and showing Engine System
Failure. Note: there was no knocking when changing gear.
Took car back. They refitted the DMF and the car drives fine apart from
the knocking when releasing clutch and the vibration. They said the
knocking was due to the teeth on the gearbox / clutch coming together
due to gap tolerances but I'm not sure I buy that.
I have scoured the forums which suggest possibly Gearbox mount. This is
possible I guess if they had to remove gearbox 3 times. But I'm not
sure.
Anyone had the same issue or suggest what the knocking is and the
vibration, I would appreciate it as I'm taking car back again on
Saturday.
Could be anything with this mob! It really sounds like the flywheel is loose. If the flywheel has been off 3 times I think new bolts might be needed. New bolts are recommended every time but normally the old bolts are ok to reuse. Good luck
are you getting vibration when the clutch is pressed? if you are then it could be a faulty clutch - i had this and had it replaced again.
Hi it could be gearbox mount causing the noise and vibration or the cv joint damaged when doing the work .
Only slightly. I feel it most when foot rests on clutch or half dipped
Turns out that the knocking is the driveshaft caused by it being taken out of the gearbox once too often. Due to be replaced in the week.
Well Flying Clutchman.....2 new driveshafts.....yes...2 near sides changed. Issue still there. They now suspect its in the wheel hub somewhere. Had car on ramp and you can hear noise as well as feel it through driveshaft when under ramp. Car going back in for hub strip down. So far not cost me anything as on warranty...which runs out on the 14th May....:-/
Car is now back - Apparantly they reused the Stretch Bolts - which is a no no.
They put new ones on and now I only hear a small clunk when reversing - I can live with that. Good to have my car back :-)
