Focus 2.0 Tdci Intermittent Starting Issue
focus diesel tdci 2.0 tdci ford focus starting starting issue intermittent starting issue
47 replies to this topic
#31 RobK
RobK
    Member
  • Budding Enthusiast
  • PipPip
  • 11 posts
  • Name: Rob
  • Ford Model: Focus 2.0 TDCi
  • Year: 2007
Posted 02 February 2014 - 09:31 PM
Hi John
Glad they helped.
As for the oil that's to be expected so nothing to worry about there.
Rob
Have something to contribute?
#32 Johnny Men
Johnny Men
    Member
  • PipPip
  • 18 posts
  • Name: John
  • Ford Model: Galaxy 2.0 TDCI Zetec
Posted 02 February 2014 - 09:36 PM
Phew! Just the original issue to worry about then ;-)
John
#33 Johnny Men
Johnny Men
    Member
  • PipPip
  • 18 posts
  • Name: John
Posted 11 February 2014 - 12:19 AM
Thought I'd post an update, since cleaning the valve body as described above, touch wood, I've not had any issues since.
One, very happy man :-)
Thanks to all that helped
John
#34 nazsky786
nazsky786
  • True Ford Enthusiast
  • 590 posts
  • Name: Naz
  • Ford Model: FOCUS MK2
  • Year: 2005
Posted 11 February 2014 - 11:05 AM
Where is this so called valve? Is its name a pcv valve? Or is it something else. I've got same problemon a 1.6 petrol 2006.
#35 RobK
RobK
    Member
  • PipPip
  • 11 posts
  • Name: Rob
  • Year: 2007
Posted 11 February 2014 - 04:51 PM
John - glad to hear this seems to have solved it for you, and happy to know it's not just me to have experienced it!
Naz - it's called an anti shudder valve. If you give it a quick search you'll find quite a lot about it, but more often related to VAG cars. There are pictures of location on the previous page, but it's not something you'd find on a petrol car though (unless I'm very much mistaken).
Rob
#36 sambo87
sambo87
  • 57 posts
  • Name: Sam
  • Ford Model: Focus Style
  • Year: 2007
Posted 11 February 2014 - 05:36 PM
Does anyone know if this valve is on the 1.8 tdci engine as I had trouble starting mine and aa man though it was the egr valve stuck cheers Sam
#37 RobK
RobK
    Member
  • PipPip
  • 11 posts
  • Name: Rob
  • Year: 2007
Posted 11 February 2014 - 05:59 PM
Hi Sam
All diesel models should have this valve. Easiest thing is to look under the bonnet!
Rob
#38 sambo87
sambo87
  • 57 posts
  • Name: Sam
  • Year: 2007
Posted 11 February 2014 - 06:02 PM
Cheers rob will have a look at the weekend and prob give it a clean I have also fitted the egr blanking plate next mission is to have it remapped :-)
#39 SeasickJustice
SeasickJustice
    Newbie
  • Pip
  • 2 posts
  • Name: Justin
  • Ford Model: Focus
Posted 17 September 2014 - 11:14 PM
Thank you for posting here about your experiences. I bought a car (4 yrs used) on Sat and it broke down on Sunday. RAC couldn't get it started and it was taken to garage. Garage managed to get it started although intermittent starting problems as described by others here. No errors on diagnostics. Warranty wouldn't cover Main Dealer, garage couldn't find a solution and said only main dealer could fix it. Car Dealer did offer to pay Ford Dealer costs but it was completely impossible for me to get out of work to move car across.
Anyway, researched online and found this thread and asked garage to check out this butterfly valve on the air intake. They did and it I had a phone call from garage calling me a Superhero. They tried cleaning it but that didnt make much of a difference so they replaced the valve. Problem sorted!
Thank you for sharing this information.
#40 supercmaxer
supercmaxer
  • 331 posts
  • Name: kervin
  • Ford Model: Focus c max
  • Year: 2004
Posted 08 October 2014 - 07:28 PM
Old post I know but I'm having the same problem.
I have cleaned the throttle body although it wasn't that dirty it did get stuck a few times when pushed closed, is there any way of testing this on the car to see if it closes correctly or closes at all.
I have a focus c max 2.0tdci.
#41 SeasickJustice
SeasickJustice
    Newbie
  • Pip
  • 2 posts
  • Name: Justin
  • Ford Model: Focus
Posted 08 October 2014 - 09:15 PM
You should try undoing the jubilee clip and disconnecting the fat hose and have someone else start the car a few times and watch the flap. It should o ly close while the engine shuts off. If it sticks, that's your prolem. Good luck.
#42 supercmaxer
supercmaxer
  • 331 posts
  • Name: kervin
  • Year: 2004
Posted 16 October 2014 - 07:08 PM
I'll give that a go.
Thanks.
Anyone know the cost of the new valve?
#43 supercmaxer
supercmaxer
  • 331 posts
  • Name: kervin
  • Year: 2004
Posted 18 October 2014 - 07:37 PM
On the pictures on previous page, just below the dip stick is a cap with a pipe coming from it I Beileve it to be the turbo pressure pipe, underneath that is also another cap, can anyone tell me if there is a pipe connected to this??
Thanks.
#44 Jimofthejungle
Jimofthejungle
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: James
  • Ford Model: Focus 1.8 TDCI Ghia
  • Year: 2004
Posted 19 December 2014 - 06:00 PM
I wonder if anyone can help.
I've read through this thread and am pretty sure I'm experiencing the same issues - unpredictably intermittent starting problem, runs fine and efficient otherwise, no fault codes and local garage have no idea (although swapped the battery thinking that was the issue).
So next time it wont start I was hopefully planning on a little self diagnosis and following the instructions posted.
However, first I'm pretty useless at mechanics. And secondly my engine doesn't look much like the pictures (very helpfully) posted by Rob K.
Mine looks more like this http://img521.images...08/p9280135.jpg
Are there any knowledgeable focus folk who can help me where to look about to locate the same pipe that leads to the anti stutter anti shudder valve so I can have a meddle?
Thanks in advance
#45 OllieC
OllieC
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Ollie
  • Ford Model: Focus 1.8 Zetec S
Posted 15 January 2015 - 01:15 AM
I own a 1.8 Focus Zetec S
Having a very similar issue to the OP. I've been in and out of the garage a few times now and besides replacing the battery leads they are unable to figure out what is wrong with it. Because the problem is so intermittent it never happens at the garage.
I have since been told that most independent garages diagnostic equipment only thoroughly check the ECU and as such it may be a sensor problem that might not be picked up by any diagnostics.
I think it may be a temperature sensor leading to an incorrect amount of fuel being pumped to the engine prior to starting. This may explain why the engine always starts for me on a 2nd attempt. The ECU has shut off at a new outside temperature. The problem does seem to happen more often when there's been a temperature change of more than 6/7 degrees between turning the car off and starting it up again.
This is just me thinking out loud, I am still planning on taking the car to ford and getting them to check all the sensors separately.
Any info anyone else can offer is always appreciated.
Not what you're looking for?
Also tagged with one or more of these keywords: focus, diesel, tdci, 2.0 tdci, ford focus, starting, starting issue, intermittent starting issue
