James Rosier
Titanium Headlights To Titanium X Headlights
9 posts in this topic
As the title sujests does anyone know anyone or how to/if its possible to change the headlights of a normal Tit to a Tit X headlights with the DRL;s etc....
Have you found some cheap Tit X headlights then? :p over £600 each from Ford!
Have a look on your wiring connector see if there are any spare connections , take a picture and i will compare the connector to mine to see if there is any difference , i would imagine the loom should be there , might just be a case of a fuse, and plug and play.
if you had lived closer , you could have tried one of mine in there
Road trip to Pree's :)
Preee likes this
Na haven't found any yet just staring to look and see if ifs possible!
I'm following this topic with interest!!
I'm not so sure it'd be plug and play though - doesn't the Titanium X with DRL's have xenon headlamps?
It does indeed! thats why im looking at maybe changing over if its possible!
I'm hoping to find out the Same thing IE will ST-3 Xenons fit in an ST-2 with halogens, just plug and play?
I'd also plan to add the auto-levelling senors and washer Jets....
