kat89h Posted May 6, 2013 Share Posted May 6, 2013 hi i was just wondering if any1 can help me , i have a 2006 ford ka . my abs light came on last wed , then the speedo has stopped working , after driving home carefully i switched off the engine , switched it back on to be greeted by the engine warning light also! ive heard this could just be the speed sensor? is there any other problems this could be? Thanks Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted May 6, 2013 Share Posted May 6, 2013 Yeah sounds like the abs sensor which im sure incorporates the speed sensor sometimes you can clean them and they're ok Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted May 6, 2013 Share Posted May 6, 2013 P.S. Welcome to the club Quote Link to comment Share on other sites More sharing options...
kat89h Posted May 6, 2013 Author Share Posted May 6, 2013 Thank you , :) . my brakes have been sqeeking for a while to when they are applied dont know if this could be linked , they work fine though , just dont want to be ripped off by the garage ! when it could be someting quite small . Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted May 6, 2013 Share Posted May 6, 2013 Shouldn't be related maybe get the garage ro look into the squeeling aswel while its in. Do you drive the car alot? Quote Link to comment Share on other sites More sharing options...
kat89h Posted May 6, 2013 Author Share Posted May 6, 2013 not much just to work and back which is only like 3/4 miles a 10 min trip , only had it since october and dont even think ive done 1000 miles yet , my dad says the sqeeking could just be dust on the brakes but its been a few weeks now. Quote Link to comment Share on other sites More sharing options...
Preee Posted May 6, 2013 Share Posted May 6, 2013 Always important to get your bakes checked out , the squealing may be due to the wear plug , meaning your pads may need changing. Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted May 6, 2013 Share Posted May 6, 2013 Mine go like that particularly through the cold wet weather and its just because I dont use them much ive had new discs and pads fitted and its stopped the problem altogether now though. You might find you're discs are a bit rusty cause theyve not been used much. Like Pree said get them checked while its in Quote Link to comment Share on other sites More sharing options...
kat89h Posted May 6, 2013 Author Share Posted May 6, 2013 thanks , i will mention it , ive herd the speed sensor going on kas can be quite common ? now to find a reasonable garage that dont over charge me coz im a young lass!! haha. Quote Link to comment Share on other sites More sharing options...
kat89h Posted May 8, 2013 Author Share Posted May 8, 2013 UPDATE! right took it to the garage this morning , and he ran the usual test on , but apparently the car was not speaking to the computer , and the hole abs system might need doing which would be around 500£ maybes get a second hand one .but said it would need proper diagnostics tests to get down to the real problem, he had to take it to his friends garage as his laptop is away for repair and has sent me there, he said it was a common problem on the fiesta but not so much the ka , does this sound right i feel like crying :( Quote Link to comment Share on other sites More sharing options...
