Willy Posted July 18, 2013 Share Posted July 18, 2013 Used my spastic wheel for the first time in 9 years today. Getting my alloy repaired after being hit by a scooter. Quote Link to comment Share on other sites More sharing options...
FiestaZS90150 Posted July 18, 2013 Share Posted July 18, 2013 i hope you hit the scooter back after he hit you lol. no pics? this is what i did today =) paid 15 for them instead of 60 =) 1 Quote Link to comment Share on other sites More sharing options...
Willy Posted July 18, 2013 Share Posted July 18, 2013 Not very exciting and yes I did get him :) Quote Link to comment Share on other sites More sharing options...
FOCA Posted August 6, 2013 Share Posted August 6, 2013 Well recently ive been very busy - I rewired my temp/ volt modules so they switch off (they were left on all the time) and reset (without having to "fiddle" with them) when i put the power back on - i had to swop the temp esnder round - one is for volts, one for water temp (for now) The main switch now turns the volt/ temp modules on and the electronic boost controller - so ive disconnected the torque restrictor defeat switch that was beside the gearstick (only used it for snow/ ice anyway) and hooked the switch up to the boost controller - now i can switch the boost off/ on quickly (without resetting the controller) - by just flicking the switch beside the gearchange - im going to experiment with this by trying a low boost setting in 1st/ and mabee 2nd to help traction (360+Nm is a lot to try to put through the front wheels without any form of traction control) I finally got my electronic pump controller hooked up - had to make a special adaptor for the temp sender so i can keep my thermostat - its working nicely and should make a big difference - before i had to keep switching the pump off/ on manually - not ideal Bled the brakes after fitting a new rear caliper - had done the other side last year and have ordered a pair of new handbrake cables - so that will be 2 new(ish on one side) calipers and 2 new cables - hopefully get my handbrake working how it should soon While i was at it i decided to paint my intercooler brackets - they are B&Q shelf brackets (in white) they were drilled and cut shorter and have been on the car a couple of years - i took them off and q-rusted them, ready for painting (might as well do these little things when the car is not being used) fitted a new interior door handle - old one had broken - took 2 mins (to my surprise) - rear door cards look a bit rough but i might get a leather interior at some point so don't know if its worth changing them for now, i might fit a set of lightweight racing seats instead - decisions - decisions 1 Quote Link to comment Share on other sites More sharing options...
georgen Posted August 6, 2013 Share Posted August 6, 2013 Well recently ive been very busy - I rewired my temp/ volt modules so they switch off (they were left on all the time) and reset (without having to "fiddle" with them) when i put the power back on - i had to swop the temp esnder round - one is for volts, one for water temp (for now) The main switch now turns the volt/ temp modules on and the electronic boost controller - so ive disconnected the torque restrictor defeat switch that was beside the gearstick (only used it for snow/ ice anyway) and hooked the switch up to the boost controller - now i can switch the boost off/ on quickly (without resetting the controller) - by just flicking the switch beside the gearchange - im going to experiment with this by trying a low boost setting in 1st/ and mabee 2nd to help traction (360+Nm is a lot to try to put through the front wheels without any form of traction control) I finally got my electronic pump controller hooked up - had to make a special adaptor for the temp sender so i can keep my thermostat - its working nicely and should make a big difference - before i had to keep switching the pump off/ on manually - not ideal Bled the brakes after fitting a new rear caliper - had done the other side last year and have ordered a pair of new handbrake cables - so that will be 2 new(ish on one side) calipers and 2 new cables - hopefully get my handbrake working how it should soon While i was at it i decided to paint my intercooler brackets - they are B&Q shelf brackets (in white) they were drilled and cut shorter and have been on the car a couple of years - i took them off and q-rusted them, ready for painting (might as well do these little things when the car is not being used) fitted a new interior door handle - old one had broken - took 2 mins (to my surprise) - rear door cards look a bit rough but i might get a leather interior at some point so don't know if its worth changing them for now, i might fit a set of lightweight racing seats instead - decisions - decisions Got out planned for Tomorrow 2 Quote Link to comment Share on other sites More sharing options...
Torchwood Posted August 8, 2013 Share Posted August 8, 2013 Been busy the last few weeks, studying for the eltricians course exams... But changed the orange indicator bulbs up front, LED side repeaters fitted. Bright white LED side lights... And car booked to go back in and have a wave of updates fitted... Finally!!! Taken ages for the parts to arrive! 1 Quote Link to comment Share on other sites More sharing options...
bigmunkynutz Posted August 11, 2013 Author Share Posted August 11, 2013 Fitted my Rally Flapz :-D 1 Quote Link to comment Share on other sites More sharing options...
rocky1722 Posted August 12, 2013 Share Posted August 12, 2013 Fitted my Rally Flapz :-D Very nice. ;) Stephen, I've spoken to Ian from Performance Creations previously about mudflaps for the new Mk7.5. Are these the new ones made specifically for the Mk7.5 or are they a set of Mk7 mudflaps modified? Want to get my Kaylan mudflaps on as soon as I get my Mk7.5. :) 1 Quote Link to comment Share on other sites More sharing options...
bigmunkynutz Posted August 12, 2013 Author Share Posted August 12, 2013 These have the newer bracket for the rear at the minute but still required a bit of modification to make them fit. I'm in contact with Ian at the minute so will feed back to him. 1 Quote Link to comment Share on other sites More sharing options...
FiestaZS90150 Posted August 12, 2013 Share Posted August 12, 2013 got an answer for a remap here in france and they do it fo r600€ 145bhp and 240nm coming from the stadard car 1.0 125bhp 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 12, 2013 Share Posted August 12, 2013 got an answer for a remap here in france and they do it fo r600€ 145bhp and 240nm coming from the stadard car 1.0 125bhp Sweet gains, but twice the price of the going rate over here. Quote Link to comment Share on other sites More sharing options...
FiestaZS90150 Posted August 12, 2013 Share Posted August 12, 2013 yeah its pricey of here. But i have only asked this one place. Im quite happy with moving from 68 to 125 =) dont think ill chuck that much money into 20 HP. I d prefer to setup another aquarium for that price XD 2 Quote Link to comment Share on other sites More sharing options...
FOCA Posted August 12, 2013 Share Posted August 12, 2013 yeah its pricey of here. But i have only asked this one place. Im quite happy with moving from 68 to 125 =) dont think ill chuck that much money into 20 HP. I d prefer to setup another aquarium for that price XD Agreed - I can't beleve im saying this but there are more important things than modifing your car - + whem money is tight you have to think about MOTs/ servicing etc etc before enhancements. 1 Quote Link to comment Share on other sites More sharing options...
Loz Cheung Posted August 12, 2013 Share Posted August 12, 2013 Found out how the ST fared against a Clio 172! Not meant to be a bragging remark as my mate had one of these 172/182's and memories of this was what made me downsize to the Fiesta! It was mainly uphill so the turbo'd torque is no surprise here, but i was expecting it to be a closer match! between 3rd + 4th gear and this was with changing up at 5,500rpm without needing to wring it to death too. chuffed B) Quote Link to comment Share on other sites More sharing options...
Sweeney367 Posted August 14, 2013 Share Posted August 14, 2013 Went and got it from the dealers! Had it less than a day and already ordered some TH Wind deflectors and new white headlight bulbs (Philips Diamond Visions for dipped and OSRAM cool blue intentse for main beam).. Next ill be ordering a Zs Front and rear spoilers! My cars Squeeze green though so gotta budget for getting them sprayed aswell.. Overall though over the moon with the car (: Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted August 14, 2013 Share Posted August 14, 2013 Killed a full set of tyres. So much so they were illegal for the ride home -.- Quote Link to comment Share on other sites More sharing options...
FOCA Posted August 14, 2013 Share Posted August 14, 2013 Killed a full set of tyres. So much so they were illegal for the ride home -.- My hero! - how did you manage to kill the rears though? Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted August 14, 2013 Share Posted August 14, 2013 My hero! - how did you manage to kill the rears though? By thinking I should switch them to the front and do more looning about :P 1 Quote Link to comment Share on other sites More sharing options...
FOCA Posted August 15, 2013 Share Posted August 15, 2013 By thinking I should switch them to the front and do more looning about :P You could get a spare set of wheels/ tyres for these ocassions (specially for "killing") Hope you got videos Quote Link to comment Share on other sites More sharing options...
bigmunkynutz Posted August 15, 2013 Author Share Posted August 15, 2013 Where should I stick my fez badge? Front grille or on engine cover? Quote Link to comment Share on other sites More sharing options...
E5GDM Posted August 15, 2013 Share Posted August 15, 2013 In the bin, less is more. Quote Link to comment Share on other sites More sharing options...
iNath Posted August 15, 2013 Share Posted August 15, 2013 Well no one will see it on the engine :p Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 15, 2013 Share Posted August 15, 2013 Put it in both places, problem solved. Quote Link to comment Share on other sites More sharing options...
andyedge Posted August 15, 2013 Share Posted August 15, 2013 Bought some presents for Fifi the 2nd :) Recently traded my old White ZS in for a used Black Metal, but the previous owner didn't treat her properly & the paintwork is covered in swirls :( Just need to book some time off work now to take the plunge into the world of machine polishing. Wish me luck! Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted August 15, 2013 Share Posted August 15, 2013 You could get a spare set of wheels/ tyres for these ocassions (specially for "killing") Hope you got videos I'm buying a set of more race-orientated tyres, RAC bailed me out this time :P did get a few videos, but unfortunately the phone strapped to the outside of the car fell off and got run over before being recovered, and I now can't get the case off lol. Quote Link to comment Share on other sites More sharing options...
