What Have You Done With Your Car Today?
505 replies to this topic
#211 E5GDM
E5GDM
  • True Ford Enthusiast
  • 668 posts
  • Name: Gary
  • Ford Model: MI 7.5 ST3
  • Year: 2014
Posted 14 July 2013 - 01:06 PM
E5GDM, looking at getting the st diffuser from European parts, how hard was it to fit ? Have you got any pictures for a guide ? Would be appreciated
All pretty straight forward....
Remove the old deffuser by first drilling out the single pot rivet at each end (there's 3 at each end, but only the inner one is for the deffuser),& then just gently pull it off (you can see the clips on the new one).
I clipped the 2 parts of the new deffuser together, then attached it to the car by pushing it on, ensuring all the clips located.
There's 2 protruding 'lugs' on the bottom of the defuser that you hinge back under the car, & using 2 nuts secure them to the bolts already in place under the spare wheel well (you'll see them when you look under the car).
Then I drilled 1 hole & used a self taper at each end (instead of pot rivets) to attach the lower ends of the new deffuser.
Then I cut back the original tail pipe to allow me to attach the tail pipe.
Job done :)
Have something to contribute?
#212 Nathan54771
Nathan54771
    Ecoboosted
  • PipPipPipPipPip
  • 1,570 posts
  • Name: Nathan
  • Ford Model: Ford Fiesta MK7.5 ST3
  • Year: 2014
Posted 14 July 2013 - 01:35 PM
Not too bad then, makes a massive improvement, did it cost you around £250 then for the diffuser, painting it and tail pipe ? Debating whether to give it a go :)
#213 E5GDM
E5GDM
  • 668 posts
  • Name: Gary
  • Year: 2014
Posted 14 July 2013 - 01:58 PM
About that, not bad I reckon :)
Go for it :)
#214 Nathan54771
Nathan54771
    Ecoboosted
  • PipPipPipPipPip
  • 1,570 posts
  • Name: Nathan
  • Year: 2014
Posted 14 July 2013 - 02:08 PM
Yehh not bad at all, you reckon it'll be harder to get it sprayed in candy blue ? or will it just cost abit more ?
#215 E5GDM
E5GDM
  • 668 posts
  • Name: Gary
  • Year: 2014
Posted 14 July 2013 - 05:34 PM
It cost me £75 to get it sprayed in my local body shop, shouldn't be any harder or cost you anymore really.
#216 bigmunkynutz
bigmunkynutz
    Ecobeast Addict
  • Members via FB
  • 371 posts
  • Name: Stephen
  • Ford Model: Mk3 Focus ST-2
  • Year: 2013
Posted 14 July 2013 - 09:33 PM
Painted my calipers gold and the disks metallic black on the front.
#217 FiestaZS90150
FiestaZS90150
  • 518 posts
  • Name: Nicolas
  • Ford Model: Ford Fiesta 2013 1.0 Ecoboost Racing Red
  • Year: 2013
Posted 15 July 2013 - 07:12 AM
Discs Metallic black?
#218 bigmunkynutz
bigmunkynutz
    Ecobeast Addict
  • Members via FB
  • 371 posts
  • Name: Stephen
  • Year: 2013
Posted 15 July 2013 - 08:34 AM
Well not the disk exactly the hub of the disk, they are already a dull black.
#219 FiestaZS90150
FiestaZS90150
  • 518 posts
  • Name: Nicolas
  • Year: 2013
Posted 15 July 2013 - 10:17 AM
I just changes my h7 bulbs un the car. The dipped beam. Is it normal is smells Like burnt plastic? From the bulb?
#220 bigmunkynutz
bigmunkynutz
    Ecobeast Addict
  • Members via FB
  • 371 posts
  • Name: Stephen
  • Year: 2013
Posted 15 July 2013 - 10:37 AM
Not sure it should Nicholas.... My HID's smell fine and I thought they got hotter than standard bulbs..
#221 FiestaZS90150
FiestaZS90150
  • 518 posts
  • Name: Nicolas
  • Year: 2013
Posted 15 July 2013 - 10:38 AM
Strange they are 55w like the standard ones. Will see what happens when I put the second one in lol
#222 E5GDM
E5GDM
  • 668 posts
  • Name: Gary
  • Year: 2014
Posted 15 July 2013 - 05:38 PM
Decided that if a jobs worth doing, it's worth doing well-
So although its not that obvious, the bit arrowed had to go
Here's a close up with tail pipe removed
Here's what it looks like once it's cut back
#223 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,585 posts
  • Name: Clive
  • Year: 2015
Posted 15 July 2013 - 07:33 PM
Looks tidier.
My job today entailed pulling my dash apart again.
This morning I discovered that my air vent control wasn't changing the vent direction anymore.
I knew that when I swapped my heater control panel over on thursday due to a duff aircon switch that I'd cracked the collar so thought it may have snapped.
On pulling everything apart I found that the wire stem goes all the way through the plastic so it was still turning but the other end had unclipped from the vent actuator at the rear.
Luckily I already had a spare wire so replaced the damaged one and ensured both ends were properly seated.
Bit of a faff but had to be done.
#224 bigmunkynutz
bigmunkynutz
    Ecobeast Addict
  • Members via FB
  • 371 posts
  • Name: Stephen
  • Year: 2013
Posted 17 July 2013 - 08:50 PM
Fitted roof bars ready for camping :D
#225 FiestaZS90150
FiestaZS90150
  • 518 posts
  • Name: Nicolas
  • Year: 2013
Posted 17 July 2013 - 09:03 PM
omg lol that doesnt look quite correct XD.
Not what you're looking for?
