Stuttering When Accelerating In 2Nd And 3Rd Gear
20 replies to this topic
#16 Zachayter
Zachayter
    Member
  • Budding Enthusiast
  • PipPip
  • 21 posts
  • Name: Zach
  • Ford Model: Somerset
  • Year: 2001
Posted 14 September 2013 - 08:12 PM
I have yet to send my ecu off for repair, perhaps a remap might work, but then as stooge says it may happen again.
Have something to contribute?
#17 beethoven
beethoven
  • 59 posts
  • Name: Thierry
  • Ford Model: mondeo tdci
  • Year: 2005
Posted 14 September 2013 - 08:29 PM
it'll probably happen again(but hope not for your sake) I had a corrupt pcm before & I did the same nearly. But as I wasnt finding the underlying problem that caused it,it came back within a few weeks. I never ever found out what caused it but an auto-sparky reckons water ingress(glorious ford again). here's hoping though eh lol
The stuttering suddenly began in May, when I started the topic. I drove around for quite some time with it, until I've had enough of it. I went to my tuner , David Daniels, aka Streetperformance Belgium, and talked about it with him.In order to solve the problem, he remapped the mondy, The stuttering was gone, but another problem came up.... <_<  :(
The acceleration was very good until about 3000 -3200 rpm's....3300rpm's and above....no torque at all and a lot of smoke :(
David thought the MAP sensor was bad ... I was looking for a new MAP sensor and found one, but not yet mounted him.
About a month ago, my wife and I took a day trip to Aachen. When we wanted to leave in the evening, the mondy did not start.
The first moment I thought: the startermotor is broken.
I called the breakdown service(? :( sorry if the word is wrong) and he tested the battery: Voltage ok, but insufficient starting power. A new battery, was his verdict :wacko: . Since battery-replacement, the problem of torque-absence/smoke has disappeared, so the MAP was not bad. And my thought is that the stuttering was also a result of a weak battery.  Possible?
#18 FOCA
FOCA
    Feet on the table
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 14 September 2013 - 10:26 PM
Glad to hear you got it sorted - did you get dyno printouts of the power/ torque?
#19 beethoven
beethoven
  • 59 posts
  • Name: Thierry
  • Year: 2005
Posted 15 September 2013 - 07:16 AM
Sorry, no dyno-printouts :( .
But there is yet another modification coming, larger injectors, which give more flow, more turbo-boost and if that goes well, I promise: then a dyno-printout.
#20 stooge75
stooge75
  • 654 posts
  • Ford Model: Mondeo tdci zetec
Posted 21 September 2013 - 05:30 PM
is your turbo electrically operated?
#21 beethoven
beethoven
  • 59 posts
  • Name: Thierry
  • Year: 2005
Posted 22 September 2013 - 04:49 PM
Sorry for the late answer:
Yup, he is.
Not what you're looking for?
