Hi everyone, just a quick query. My brother has a 61 plate zetec s, as were I only have the 10 plate zetec s, I've heard a lot about DPFs, and I'm unsure as to whether I have one or not. I know he does because its after March 2010, but not sure if mine does. No websites give any good ideas so I'll tell a bit more. Mine has the streetpack wheels and apparently they stopped them just before the 95ps engine came out, but then mine was registered 02 03 2010, and apparently in march they changed so im unsure as to whether I do, is there a way to tell or can someone tell me outright just for by the info given. If you need anymore info I can try help.
Thanks very much guys :)
id be surprised if you dont have one as all diesels are euro IV compliant. On the plus side, you should have a CDPF which is maintenance free!
Apperently they didn't fit the dpf on the 90ps version only on the 95ps, so not sure if mine is or not, how will I find out do you know?
thanks
aarron
easiest answer - call Ford give them the car details, and they will tell you!
go to ford etis website (etis.ford.com) and put your number plate in, see what comes up along side the engine and efficiency?
