Need Help
6 replies to this topic
#1 STRETCH2009.
STRETCH2009.
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: anthony
  • Ford Model: focus
  • Year: 2006
Posted 13 May 2013 - 10:38 PM
hi guys i bought a 1.8 tdci sport focus but when i get in it strat the engine some times there is no revs at all then it will kick in i took it to a garage today and the codes come up are 0336  1632  0100 and 1260 anyone no what they mean and do u think it would b to do with any of these the problem thanks guys im new so need a bit of help lol
Have something to contribute?
#2 FOCA
FOCA
    Feet on the table
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 14 May 2013 - 04:26 AM
These are what the fault codes mean -
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P1632 Smart Alternator Faults Sensor/Circuit Malfunction
P0100 Mass Air Flow Circuit Malfunction
P1260 THEFT Detected, Vehicle Immobilzed
I would check it has the correct (silver calcium) type of battery fitted, and look at the alternator 1st, as voltage changes/ fluctuations can sometimes generate spurious fault codes.
#3 STRETCH2009.
STRETCH2009.
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: anthony
  • Ford Model: focus
  • Year: 2006
Posted 14 May 2013 - 06:39 PM
i went to the garage today cos the light come bk on and the only code that come up is p0100 air mass so dont no if i should get a new one or c if the pin is broke like one of the guys had on here
#4 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 14 May 2013 - 09:18 PM
Voltage fluctuations can sometimes generate spurious fault codes -
(if the cars' battery voltage is wrong you can get false fault codes from sensors that are really ok, or one code/ fault can cause more fault codes- like a chain reaction)
Look at the MAF sensor connector and if no pins are broken, clean the connections and just put it back on, it might just be a loose/ bad connection (and save you paying for a new one) - the actual sensor is delicate and must be cleaned carefully
#5 STRETCH2009.
STRETCH2009.
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: anthony
  • Ford Model: focus
  • Year: 2006
Posted 14 May 2013 - 09:44 PM
ok when i do that do i have to go and get the eml turned off b4 i will c if that worked is there anyway of seeing if it is the maf its self
#6 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 15 May 2013 - 12:04 AM
Unless  the MAF is obviously phisically broken or damaged its difficolt to tell, you can buy a code reader for about £20 that you can read your codes and reset them as often as you like (F-super, available online - you will need a windows pc with a USB port)
Just because the Air mass flow is "out of range" / "circuit malfunction",does not nessesarily mean the MAF itself is faulty
Some mechanics disconnect the MAF and drive the car around to see if it makes any difference
Do you have a multimeter or can you aquire one?
#7 STRETCH2009.
STRETCH2009.
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: anthony
  • Ford Model: focus
  • Year: 2006
Posted 15 May 2013 - 11:41 AM
i dont have a multimeter but yes i can buy one and i was thinking of unplugging the maf and driving it to c if it does anything or stays the same what should the volts b on all the pins if i get a multimeter
Not what you're looking for?
