Grease Idler Pulleys?
6 replies to this topic
#1 zetec4
zetec4
  • New Member
  • 32 posts
  • Ford Model: fiesta mk4 zetec
Posted 21 May 2013 - 12:14 PM
Is it reccomended to grease the idler pulleys? Where they seat? The one ribbed one has a bearing type obv,
But should I apply a film of grease to it
Have something to contribute?
#2 Steelie600
Steelie600
    Master Techncian
  • Members via FB
  • 147 posts
  • Name: Kev
  • Ford Model: Escort Van 55
  • Year: 2001
Posted 21 May 2013 - 12:55 PM
No they are sealed units. They should be replaced when the cambelt is changed. But it has been known for them to fail before hand. But no theyre not a servicable item.
#3 zetec4
zetec4
  • New Member
  • 32 posts
Posted 21 May 2013 - 01:01 PM
Yeah I've got all new idler pulleys tensioner belt and crank, I just put a bit of grease where the idler pulley bearing actually mounts on to the pivot so it's not completely dry, thread locked and torqued the torx bolt down
#4 stooge75
stooge75
  • True Ford Enthusiast
  • 654 posts
  • Ford Model: Mondeo tdci zetec
Posted 21 May 2013 - 01:39 PM
It wont make any difference. Been there n done that. New pulley is the answer. Are you getting the rattle? I renewed my crank,pulleys and spring. Rattles starting to reappear i think. Im waiting on the upgraded clutch pulley for alternator then im gonna try that n see if it makes a diff
#5 zetec4
zetec4
  • New Member
  • 32 posts
Posted 21 May 2013 - 05:08 PM
It was shaking, the tensioner was completely fubard, the mounting for the spring was loose and bolt was rounded off so someone's been down there,
#6 stooge75
stooge75
  • 654 posts
Posted 21 May 2013 - 05:52 PM
mines was exactly the same,but i managed to keep the tensioner & just replace the spring. the bush on the old spring was worn nearly all the way through. Im sure its down to mondeo's having no clutch pulley on alternator plus a dodgy crank pulley.my clutch pulley is my next job right after my egr delete map in couple weeks.did you have to buy a complete tensioner then? from ford(ouch)?
#7 zetec4
zetec4
  • New Member
  • 32 posts
Posted 21 May 2013 - 09:13 PM
lol nah, ebay tensioner was £35, drivebelt was gates at £9
Not what you're looking for?
