suddste Posted May 21, 2013 Share Posted May 21, 2013 Hello, My car has one cigarette lighter socketand one accessory socket and they are both live all the time. I want itso it turns on only when the key is turned as I have a dash camera nowand cant have it draw from the battery all the time or it will go flat. Iheard its just a case of changing the fuse to another position, is thatthe case, if not how do you do it? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 22, 2013 Share Posted May 22, 2013 You would have to ensure that the power source is of a suitable amperage rating (20A). Quote Link to comment Share on other sites More sharing options...
suddste Posted May 23, 2013 Author Share Posted May 23, 2013 You would have to ensure that the power source is of a suitable amperage rating (20A). Is that hard>? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 23, 2013 Share Posted May 23, 2013 A case of digging through a wiring diagram for an ignition switched 20A source. Quote Link to comment Share on other sites More sharing options...
ferretfloozy Posted May 23, 2013 Share Posted May 23, 2013 or connect the lighter socket supply to a 12v normally open relay and use the ignition acc to activate it Quote Link to comment Share on other sites More sharing options...
billybob66 Posted May 23, 2013 Share Posted May 23, 2013 this is somthing i have thought about, one idea i had was to put in a second lighter next to the first one. the second one would only come on with the ignition. so if your phone is plugged in hidden it will still charge on number one. but your camera will turn off, when you leave the car on number two. one thing is worth thinking about is, if you where to have a minor bump the first thing you would do is take out your keys when you get out of the car. but you still need the camera recording. this wont happen, the camera connected to the acc supply will turn off after a couple of minutes. what camera have you got? and what sized card are you recording on too? EDIT... just reread your first post and you all ready have two sockets so you only need to change the supply for one, ferretflooozy's idea sounds good to me. but please do let us know what camera you have and maybe a link on where to get one. :) Quote Link to comment Share on other sites More sharing options...
SeanW Posted May 24, 2013 Share Posted May 24, 2013 John, as/when/if you succeed, care to share? I'd like mine to do the same (same reason too) Quote Link to comment Share on other sites More sharing options...
suddste Posted May 24, 2013 Author Share Posted May 24, 2013 this is somthing i have thought about, one idea i had was to put in a second lighter next to the first one. the second one would only come on with the ignition. so if your phone is plugged in hidden it will still charge on number one. but your camera will turn off, when you leave the car on number two. one thing is worth thinking about is, if you where to have a minor bump the first thing you would do is take out your keys when you get out of the car. but you still need the camera recording. this wont happen, the camera connected to the acc supply will turn off after a couple of minutes. what camera have you got? and what sized card are you recording on too? EDIT... just reread your first post and you all ready have two sockets so you only need to change the supply for one, ferretflooozy's idea sounds good to me. but please do let us know what camera you have and maybe a link on where to get one. :) Hello, yes the camera is a Prestigio Roadrunner HD1, availible from amazon. I wouldnt recommend it! The card I use is a 16GB card. Quote Link to comment Share on other sites More sharing options...
