mn2 Posted March 26, 2009 Share Posted March 26, 2009 Hello can any one help i have a mk 1 focus no a 1999 the central locking s just stopped working not even the button no the dash which open s the boot work s any more the only way to open the car is to un lock each door by hand or by the key thank s Quote Link to comment Share on other sites More sharing options...
anabol_lectar Posted March 26, 2009 Share Posted March 26, 2009 Hi mate, I had similar problem. Found out the fuse had blown. If you look under passenger side dash it is located there. You will have to remove the container that holds your stuff in the dash. Then work the fuse box down to the floor, that bit is a bit of a struggle and can be a pain in the !Removed!, but you should be fine. Then just a simple matter of changing the fuse ;) It would be a good idea to not put it back to its original place for a day or two incase the fuse goes again... which happened to me so to save you the hassle I would put it back to its home after a couple of days just incase the fuse does go later that day or following day. If it does go then it suggests one of your remote central locking mechanisms is faulty, which happened to me. Hope this helps :D Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 26, 2009 Share Posted March 26, 2009 Hi mate, I had similar problem. Found out the fuse had blown. If you look under passenger side dash it is located there. You will have to remove the container that holds your stuff in the dash. Then work the fuse box down to the floor, that bit is a bit of a struggle and can be a pain in the !Removed!, but you should be fine. Then just a simple matter of changing the fuse ;) It would be a good idea to not put it back to its original place for a day or two incase the fuse goes again... which happened to me so to save you the hassle I would put it back to its home after a couple of days just incase the fuse does go later that day or following day. If it does go then it suggests one of your remote central locking mechanisms is faulty, which happened to me. Hope this helps :D if you squeeze the sides of the glove box in, the glove box should drop no problem. ive not had any problems with it on my car yet, pulled out very easily. but as said, check the fuses behind the glove box Quote Link to comment Share on other sites More sharing options...
mn1 Posted March 27, 2009 Share Posted March 27, 2009 hello mate thank you i will have a look i have had the fuse box out all fuse are ok so i will take a look ate the locking side off it thank you Quote Link to comment Share on other sites More sharing options...
anabol_lectar Posted March 27, 2009 Share Posted March 27, 2009 hello mate thank you i will have a look i have had the fuse box out all fuse are ok so i will take a look ate the locking side off it thank you Thats a shame mate that its not simly a fuse. I had to replace my passenger side mechanism not cheap from dealer, I ended up getting it from a local breakers. Quote Link to comment Share on other sites More sharing options...
fordtech Posted March 27, 2009 Share Posted March 27, 2009 hello mate thank you i will have a look i have had the fuse box out all fuse are ok so i will take a look ate the locking side off it thank you The fuse is on the back side of the fusebox and obscured by the wiring. Quote Link to comment Share on other sites More sharing options...
