Tunnig
4 replies to this topic
#1 Ste's little diesel
Ste's little diesel
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Steven
  • Ford Model: Ford focus 1.6 tdci
  • Year: 2005
Posted 25 May 2013 - 05:46 PM
Hi all,
I have got myself a 1.6 tdci on a 55 plate, and I must say I love it, I have allways had performance cars in the past put as times have changed I had to get something that would do more than 15 miles to the gallon, however I am thinking of putting a dump valve on her just for my own fun really, just wonderd if it was even possible and if anybody know where I could get one from
Have something to contribute?
#2 FOCA
FOCA
    Feet on the table
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 25 May 2013 - 07:46 PM
Its "tuning" (MY spelling is always pewefectt) :lol:
A conventional dump valve is a waste of time on a diesel because there are no throttle butterfies in the inlet manifold like a petrol turbo , even  modern petrol turbo cars may have recirculating valves and don't need dump valves/ dump valves may loose boost = power
So its only certain types (usually older) of petrol turbo engines that actually benifit from add-on  dump valves, for everything else, they are useless
You can get a machine that makes a "hiss"/ dump valve noise when you change gear, its electronic and is not connected to the engine directly, the really good thing about it is you can switch it off
You would be better off getting a remap , then possibly some exhaust mods (a DPF delete if it has one) and a freer- flowing inlet an EGR blanking plate (solid stainless steel) is a good idea too -
Lennys Guide to fitting EGR blanking plate -
http://www.fordowner...-16tdci-engine/
Before anyone comments on the dump valves in my signature (on a diesel Mondeo) one is an overboost dump valve that "dumps" exess pressure from the inlet manifold if i turn my boost too high or if i have a wastegate/ boost control failure, (and is closed/ silent in normal use) and the other "dumps" pressure out of the actuator so the wasegate is closed when i re - open the throttle (after a lift-off or gearchange) this is silent / "dumps" back into the turbo outlet (so ne boost pressure is lost)  - niether hiss when changing gear and are different from conventional dump valves
#3 Ste's little diesel
Ste's little diesel
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Steven
  • Year: 2005
Posted 25 May 2013 - 10:25 PM
Nice one, thanks for the advice, and the spelling lesson, lol
Will check that link out
#4 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 26 May 2013 - 03:46 AM
No problemo!
I had a look around and i found this -
http://www.ebay.co.u...#ht_4297wt_1526
and this -
http://www.ebay.co.u...e#ht_1138wt_904
and a real dump valve - (cheaper than the fake electronic one!)
http://www.ebay.co.u...e#ht_1183wt_932
#5 Ste's little diesel
Ste's little diesel
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Steven
  • Year: 2005
Posted 26 May 2013 - 01:29 PM
Nice one, thanks for the help.
Not what you're looking for?
