alig301 Posted May 27, 2013 Share Posted May 27, 2013 Hi all, I have just replaced the fuel filter on an 06 Focus 1.6 TDCi as I had a Engine warning Fault and associated static red led. I have since got the car running after a lot of effort but initially after I got it going, the light disappeared, but after about 5 mins the warning and light re-appeared. Anyone got any further suggestions before I hand it to the expensive 'Technicians' regards AliG Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 27, 2013 Share Posted May 27, 2013 silly question, but we have to ask.. did you install the fuel filter the correct way around? and was the filter housing integral, or perhaps in need of replacing? It sounds like if you did have it correct and the housing was fine, then it could be a case of fuel pump might be the next place to look... Quote Link to comment Share on other sites More sharing options...
johnH Posted May 27, 2013 Share Posted May 27, 2013 Can you post any codes that you have on the dash or scanner? Quote Link to comment Share on other sites More sharing options...
