Highwaymanuk
Blaupunkt Sat Nav
5 posts in this topic
I've got a BLAUPUNKT HS RNS MCA Sat Nav in the car but it has recently given up finding satellites. Has anybody else had this problem, any ideas on how to fix it?
Has your GPS aerial shifted, unplugged or packed up?
Hadn't thought about aerial becoming unplugged. (Fingers crossed easy fix) Its the factory unit so is the GPS aerial at the base of the radio one or is that for DAB? If not where would I find the GPS aerial?
Cheers for help.
Pull the radio out , you can then trace it , it's either right side behind the instrument cluster or it goes further up the drivers pillar to the aerial in the roof lining
