Guide To Complete Stereo Installation Focus Mk2
Aftermarked Head Unit 3-Way Active Crossover Sound Dampening Car Alarm
54 replies to this topic
#31 Lenny
    Retired Moderator
  • 10,429 posts
  • Ford Model: Focus ZetecS
Posted 30 July 2013 - 02:44 PM
Thank you :)
I really recommend getting the Haynes Manual to do the removal of the inner panel. But I will try to describe how to do it.
Loosen the rubber grommits - the green ones - the opening handle wire can be easily removed form the opening handle.
The red circles: the inner panel holds the power windows mechanism, with the window glass attach to it. First remove the rubber inner weather strip from the door. Remove the two rubber sealings in the red circles (glue them back on when tou're finished) lower the windows until you see 10mm bolts - looking in to the holes - loosen the bolts - then grab with both hands on top of the window glass (tilting it up at the rear) and carefully slide it up and out of the door completely.
Blue circle - these 3 plastic plugs are holding locking mechanism - which are attach to the door. To loosen the locking mechanism you have to remove the outer door  handle (and a bolt behind it) and the 4 bolts at the end of the door. I have not done this - I did carefulley remove the 3 black plastic plugs just to get the inner panel off.
Hope this helps you.
Thanks very much for this information mate,
Some how I missed this thread until now,
I'm installing the ford puddle lights and I need to run cable through the rubber pipe of the door loom
So basically I need to get in there to fish cable through,
Makes it easier seeing you have been there before and survived gives me hope that I will too.
Have something to contribute?
#32 gazsutton
gazsutton
    Clueless!
  • Budding Enthusiast
  • 133 posts
  • Name: Gareth
  • Ford Model: Ford Focus Zetec S
Posted 31 July 2013 - 11:59 AM
that is a great guide!!!
#33 Mr_Spock
Mr_Spock
  • 83 posts
  • Name: Tom
  • Ford Model: Ford Focus 1.6 Petrol Hatch
  • Year: 2005
Posted 31 July 2013 - 12:38 PM
Thank you :)
#34 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Ford Model: Focus 1.8TDCI Titanium
  • Year: 2009
Posted 23 March 2014 - 05:18 PM
Where do you route Amplifiers cables, from engine bay to cabin? Kinda intrested because i've making same thing as you
#35 Mr_Spock
Mr_Spock
  • 83 posts
  • Name: Tom
  • Year: 2005
Posted 23 March 2014 - 05:54 PM
I used an already made hole, it's on the right side on my car - it is where most of the electric cables from the engine bay comes through. I just widened the big rubber gasket. Good luck with your project :)
#36 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 23 March 2014 - 06:02 PM
You mean ECU/MJB cables inlet near a-pillar? Need a hole for a 50mm2 cable. I had only 5.2meter, and car is wagon, but i think floorpan is still the same. Nice ICE install btw. :)
#37 Mr_Spock
Mr_Spock
  • 83 posts
  • Name: Tom
  • Year: 2005
Posted 23 March 2014 - 08:35 PM
It is right behind the Glove Compartment on my car - big hole - no problem with a 50mm2 cable.
Thanks for liking the installation - it still sounds amazing.
#38 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 24 March 2014 - 04:44 PM
OK, do you have link ebay page where you find those speaker adapters? I think i change original set to Pioneer/DLS 5.25" sets.
#39 Mr_Spock
Mr_Spock
  • 83 posts
  • Name: Tom
  • Year: 2005
Posted 24 March 2014 - 05:24 PM
It is the same type as these:
http://www.ebay.co.u...383158666&rt=nc
You may find them cheaper, if you search around a little.
#40 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 28 March 2014 - 10:04 PM
I had a look under the carpets today and there was barely any dampening, mostly exposed metal. I drive a diesel, which is fairly quiet but on motorways, the sound gets in the way of listening to my music and it's starting to annoy me. Also, trying to have a conversation with my wife in the passenger seat is not that easy.
My future plans would be to save up to get the bulk pack of Dynamat Extreme, a roller kit and maybe a Haynes manual as well for good measure. Then, slowly on weekends and evenings do the panels slowly until it is all done as time is a big issue for me. That's my tentative plan so far. Any advice on how to get the Dynamat properly would be appreciated.
Is that what model, Trend, Titanium, Ghia? Because i have Titanium, and under carpet i have abt. 10mm thick layer damper from factory. (I think they add Nordic versions, mm. like Titanium Ghia) Or maybe when someone orders specially sound damping, when order newone
#41 Hassen
Hassen
  • 774 posts
  • Name: Hassen
Posted 29 March 2014 - 02:54 PM
My car is a 2010 Zetec 1.6 TDCI. Under the carpet, there is a grey type of mat material. I thought there might be something bonded to the metal rather like in other cars to stop vibration getting in the way of listening to music. Planning to get Silent Coat onto the metal after stripping the inside of the car during the summer. From research, it's cheaper than Dynamat and as effective apparently.
#42 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 30 March 2014 - 05:37 PM
I'm not familiar with Zetec type model, but i think it's same as here called ECOnetic, or GB model Zetec S is here that ECOnetic.
#43 Hassen
Hassen
  • 774 posts
  • Name: Hassen
Posted 31 March 2014 - 10:01 PM
The Zetec S they have in Uk would be similar. From the picture on your account, if that's your current car, mine would be the same I think.
#44 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 31 March 2014 - 11:06 PM
Mine is Titanium variation, just below Ghia. btw. sorry off topic ;)
#45 Nighthawk
Nighthawk
  • 402 posts
  • Name: Richard
  • Ford Model: Escort Popular Plus
  • Year: 1990
Posted 31 March 2014 - 11:45 PM
I thought Titanium was above Ghia? At least it was on our C Max.
Sent from my HUAWEI Ascend P2 using Ford OC mobile app
Not what you're looking for?
Also tagged with one or more of these keywords: Aftermarked Head Unit, 3-Way Active Crossover, Sound Dampening, Car Alarm
