Manny444
I Just Replaced My Starter Motor And Now My Battery Isnt Charging ?
I had a problem with my starter motor clicking when engaging and disengaging, i had it replaced and that fixed the starting problem. Later that day my battery warning light began to flicker but when i accellerated it went away.
I checked the voltage on my battery whith the engine running and it was only showing 12.05 volts, the following day i checked it and it was showing 11.8 volts. So the alternator is not charging the battery what so ever. Could this be down to the starter motor being slightly more powerful then the original Ford Starter Motor.
no mate, its a seperate circuit
check the battery connections and possibly the earth connection on the gearbox bell housing, they might have been disturbed when changing the starter
A good trick i use when in doubt of an earth connection is to connect a jump lead from the negative battery terminal to a clean metal part of the engine or gearbox
A very good suggestion there Stef!
It sounds like if anything the alternator isnt connecting properly. Is there any chance you may have rubbed and slightly loosened any of the connectors to the alternator?
