aliislekzade Posted June 2, 2013 Share Posted June 2, 2013 my focus mk2 front fog lights not working , and not seen in cluster icon , what is the problem ?? is there any fuse problem ?? where is it fuse ?? Quote Link to comment Share on other sites More sharing options...
aliislekzade Posted June 2, 2013 Author Share Posted June 2, 2013 is there any problem with light switch ??? or it is a fuse problem ?? where is fog fuses ?? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 2, 2013 Share Posted June 2, 2013 There's a link to the MK2 fusebox layout on my signature below this post. (Fuse 69 20 amp) Tbh it sounds like you could have a faulty headlight switch. Change the fuse first and see how you go. The fuse box is up under the passenger footwell, two twist tabs and it drops down. Pull the board towards you so the rear lugs drop into lower slots and then the board will hang straight down for better access. Quote Link to comment Share on other sites More sharing options...
aliislekzade Posted June 2, 2013 Author Share Posted June 2, 2013 thank you , first i will look to fuse , if there is no problem , i will change light switch. Quote Link to comment Share on other sites More sharing options...
aliislekzade Posted June 2, 2013 Author Share Posted June 2, 2013 and there is another system on my focus, at night time when you unlock the car from remote control , fog lights come on about 30 seconds, is there any problem about this system, and is it effect the light switch working ?? Quote Link to comment Share on other sites More sharing options...
aliislekzade Posted June 2, 2013 Author Share Posted June 2, 2013 i fix it :) problem is back of the light switch socket pin. i remove it and wore it again. its ok now. thank you . Quote Link to comment Share on other sites More sharing options...
