cooling fan
3 replies to this topic
#1 vecky03
vecky03
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: STREETKA
Posted 27 March 2009 - 10:49 AM
I have a 2003 Streetka with a cooling fan problem, the fan comes on after about five minutes driving. I have checked the water and it does not boil over or overheat?
Any ideas welcome :(
Have something to contribute?
#2 delboy
delboy
  • True Ford Enthusiast
  • 536 posts
  • Name: martin
  • Ford Model: c-max ghia 1.8 petrol /ka 1.2 mk2
  • Year: 2004
Posted 27 March 2009 - 01:57 PM
sounds like you have either a duff relay or a duff sender unit.
does your temp needle move inside the cAR ON THE DASH ??
how long have you had the car & has it had any work done to it under the bonnet to the engine
as sometimes the temp sender unit wires can get crossed with the temp wire.
they ar located on the top lh side i think atleas the thermostat is & it's usually on the stat & the hose that's off the rediator
the water temp unit in on the rh side . it looks like a spark plug going into the engine casing with a wire plugged onto it
#3 roly
roly
    Newbie
  • New Member
  • Pip
  • 6 posts
  • Ford Model: Streetka
Posted 12 April 2009 - 02:31 PM
I don't think the streetka has a temp gauge just a thermometer light that comes on when its too late. :blink:
#4 vecky03
vecky03
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 23 June 2009 - 09:52 PM
Finally found the fault of the fan coming on, thermostat faulty :rolleyes:
Not what you're looking for?
