2002 Zetec S Turbo Noise?
12 replies to this topic
#1 Road Rob
Road Rob
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Rob
  • Ford Model: tdci zetec s
  • Year: 2002
Posted 03 June 2013 - 08:43 PM
Recently got a zetec s 130bhp. I've now noticed a noise that seems to come from the turbo, it started off as a bit of a whistle under acceleration which didn't sound too bad but its now a horrible sounding rattle. I'm praying its something simple but if anyone has an idea what it could be i would be very grateful. Good news or bad I need to sort this out! Thanks.
Have something to contribute?
#2 FOCA
FOCA
    Feet on the table
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 03 June 2013 - 09:05 PM
Hello and welcome to the forum!
When does the noise happen? (under heavy acceleration/ when you lift off the throttle etc )
are there any other symptoms? (lack of power/ exessive smoke etc)
Have you had the codes read?
#3 Road Rob
Road Rob
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Rob
  • Year: 2002
Posted 04 June 2013 - 05:14 AM
Definite lack of power, white smoke and now its more of a screech than a rattle :-(
#4 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 04 June 2013 - 09:26 AM
Its often difficult to diagnose faults at a distance but here goes some things that might help-
If you take the hose between the air filter and turbo off, you can get into the turbo (compressor wheel), with the engine switched off you can check if the turbo spins ok with your fingers and if there is exessive play in the bearing (by shaking it up & down) it should spin freely and there should only be about a mm of play, up & down, (and it should hardly make any noise)
With the airbox-to-turbo hose off, keeping your hands away from the turbo compressor/ impeller, and making sure there is nothing aroung it not fixed down (that could be sucked in) get someone to start the engine and rev it up (with/ without the hose on)- is the "screech" louder (it may make "wooshing" and "hissing" noises)
You have a 2002 Mondeo, so it won't be a euro4 with electronic actuator, it will be a euro3 with a pnumatic actuator, and it probably has a VNT and a front- mounted EGR, there are other ones, though, some had fixed-vane turbos, and some rear-mounted EGRs,
If you decide (in the future) to obtain a secondhand turbo, it will be important to get the right one, and the VNT has a tendency to get "coked up"/ sieze (this cannot happen on a fixed-vane turbo) so it would be helpful for you to take some pictures of the turbo/ manifold/ whole engine (with the plastic cover off) to see which type it is/ or it might help me spot a problem
If it has a VNT turbo (Variable Nozzle Turbo/ aka variable vane turbo) the vanes can get "sticky" and when the actuator moves them it may make a noise, - see if this is the noise you are hearing (by seeing if the noise coincides with the actuator rod moving) - you can also move it with your hands / use mole grips (carefully) if it is stiff - with the engine not running
All sorts of things can make noises - belts, power steering pumps, waterpumps etc etc etc, its important not to get to focussed on one thing or assume that it is one problem or another - a mechanic would have the fault codes read and a visual inspection/ listen to the noise/ try different things to pinpoint the fault, and noises/ sounds can be difficult to describe with words
On this age of car turbo boost hoses are bad for splitting, on a front- mounted egr (mk3 mondeo diesel) engine the 1st place to check is the hose between the egr and the intercooler - the split can be hard to see/ spot without taking the hose off
2002 diesels will be OBD1 and not OBD2 compatible, garages/ mechanics are often unaware of this and sometimes cant understand why their code readers (including £££££££, ones) don't work, if you are buying a code reader yorself, make sure its compatible, i can help you with this if you like (garage may charge £80 to get codes read, once, you can buy your own for £25 and do it as often as you like)
Lastly,  with you having a 2002 car, its ok to blank the EGR (solid plate) with no problems (if its not already been done)
#5 Road Rob
Road Rob
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Rob
  • Year: 2002
Posted 04 June 2013 - 02:35 PM
Hi FOCA and thanks for all the info. You will have to excuse my limited knowledge (i used to do all sorts with bikes and cars in my younger day but not any stuff with turbos) I am however keen to learn and if I can do it myself and save a few bob then I will! I've been reading up a bit and understand more about fixed and variable vane but not enough to know which mine is by looking at it. The EGR is located near the turbo as far as I can tell (you said some were front mounted?) There doesn't appear to be any splits in the pipe.
I've just put it on the drive after limping home this morning and the smoke was worse than ever, took the hose off and the impeller has loads of sideways movement. Even I know this isn't good! You mentioned taking pics... I'm assuming I can post them on here? From what I've said would you say the turbo's definitely a goner?
Thanks again
#6 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 04 June 2013 - 05:03 PM
Here is a Mondeo mk3 TDCI euro3 with VNT & pnumatic actuator , front mounted EGR valve (illistrated) -
a different type -  fixed vane turbo -
(see the actuator "can" is transverse, not longditudinal, realative to the car) the manifold comes in from the other side, and it has a rear mounted EGR , it is a TDDI, but you get TDCIs with the same layout -
How much up and down play is in your compressor wheel? (in mm)
#7 Road Rob
Road Rob
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Rob
  • Year: 2002
Posted 04 June 2013 - 06:28 PM
Its definitely a euro3 pneumatic EGR, it's just like the 1st illustration. The amount of play feels like more than 5 mm. It's woobbling all over the place.
#8 stooge75
stooge75
  • 654 posts
  • Ford Model: Mondeo tdci zetec
Posted 04 June 2013 - 07:26 PM
its kaput. dont drive it til you get it sorted. You might be better getting yours refurb'd rather than buy a dodgy 2nd hand one.If you drive it & it fails completely,you're looking at a new engine
#9 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 04 June 2013 - 10:29 PM
Guess what - its the turbo - the cartrige bearing to be precise - bits of swarf can drop into the oil which can cause engine damage, so its a good idea not to drive the car
You could buy a new or refurbished cartrige (turbine/ compressor, and bearing housing) and fit it on (i would decoke the VNT mech and change the oil/ filter as well)
A cheaper option is to buy a secondhand turbo from a breakers, you can get one from about £100 for the whole thing, including exhaust manifold, and complete turbo
Frequent oil changes and allowing the turbo to spool down when its hot help it last longer , the reverse shortens its life
#10 Road Rob
Road Rob
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Rob
  • Year: 2002
Posted 05 June 2013 - 10:46 AM
I think I'm best finding one at a breakers rather than sourcing one online then I'll have a better idea if its a good one.
Thank you for all your help and advice
#11 Road Rob
Road Rob
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Rob
  • Year: 2002
Posted 06 June 2013 - 10:25 AM
Also I realise it has to be a vnt with pnumatic actuator and front mounted EGR but is this set up found on later cars and can I use one from a later model? And does it have to be a 130bhp like mine or can it be from a 115?
#12 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 06 June 2013 - 12:38 PM
Yes, It has to be a vnt with a pnumatic actuator, the fixed vane is tottaly different, even the exhaust manifold, it is theoretically possible to graft a fixed- vane one on, but you will need the entire assembly, including exhaust manifold and it would probably be a lot of hassle
Again, it is "possible" to fit one with an electronic actuator, but you would have to change a lot of parts, including the ECU, a lot of tuners did the opposite - (convert the euro4/ electronic actuator into euro3 pnumatic)
So for you it is best to stick with a VNT with a pnumatic actuator (that looks like the one fitted) it does not matter if it is 130PS or 115PS, they are the same (they may have scores of different part no.s, and the 2.2 has a couple more fins, allegedly)
#13 Road Rob
Road Rob
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Rob
  • Year: 2002
Posted 09 June 2013 - 11:38 AM
Ok thanks, ive been looking into getting a repair kit but i guess if when I get the turbo off its more damaged than just the bearings then i'll have to get a complete unit
Not what you're looking for?
