Mk2 Xenon Headlamp Retrofit
jon-v8
Check the car with xenons for where where the loom comes from
Ive seen garages offering HID conversion Kits for £250 i think it was,that doesnt seem to expensive too me?
Yeap, but I prefer OEM not chinese s**t ;)
Them hid conversion kits are not the proper xenon system. Legal xenon system. You will blind people with them. You need to have the correct lens which are projector not halogen reflective. You also need them leveled or you would be the blind one on the road . And then you need them always clean so you get headlight washers.
The 10 pin loom inside of the engine bay and headlight is not only for HID it is also for AFS there is a slight difference in wiring for the two. The same headlight controll module is used but the "jumper" setup is different.
So a car with wiring for HID may actually be wiring for AFS. Same wires
Yes, so i'd looked on schem. I've try to find dash wiring harnesss for xenon but salvage yard don't store them here, don't know why (after all it still valuable for those who built on them self). eBay hasn't to offer also.
There is an rs loom floating about on eBay for £400
There is an rs loom floating about on ebay for £400
Quite expensive, for peace of cables, Here i can almoust get half of car with that price (~500€) All i need is a dash loom, or Xenon part of it. ;) :)
Yeah it is overpriced but also valuable to people who know what to do with it.
Xenon retrofit is a very expensive mod
I just noticed my headlights going up and down .
I havnt even plugged in the sensors yet. Havnt even made holes for washers but it looked so good. Lights going up and down.
What mods you have made?
For the headlights the only mods as off yet are the hid module installed, and rear level sensor installed and st headlights. Still need to find the correct front level sensor and install the jets. And get the covers for jets. Almost there really just need some remaining parts and know how to put the jets on, to scared to cut the bumper.
Nice, have you that wiring setup original or have made rewiring for module? Here some pics for frontsensor
post-52548-0-31272300-1401467599_thumb.j
post-52548-0-37310400-1402667661_thumb.j
I got the wrong one. Turns out it's from a rs not st. I didn't do what you are planning on doing I just completely replace the dashboard loom with rs.
Rs and st uses the same type, all other model use another type. All to do with suspension setup.
Do you mean that your xenons go up and down when you first start the car?
I have the rear one it looks correct the front one looks wrong. Yh when you first start the car. So i know the headlights and the module work now. Now it to install the jets and the sensors.
You can see that one sensor looks like it's from another car. And it's missing a bracket.
Normal Car and ST has same setup on front, but RS front suspension has revonukle, it bit different than normal, as far i understand.
Front sensor normal/ST
Edited by Megado
That's prob why. I need to find a front st level sensor. Going to get the bolts from Ford unless they are already there.
Why Ford they just same any shop who retail bolt/nuts, Ford has just little FoMoCo extra on price ;)
Check for pictures code for frontsensor
But solves the headache of trying to find out the size etc etc. I just go down road get bolts and done.
Yes indeed does, but all you need to test fit, and measure bolt holes and length, that's i gonna do.
It's cheap enough from ford and you'll know for sure all fixings for sensors come as a set.
The up and down movement at start is self testing.
Did you activate it on elm? Probably was already activity in module
I would just get bolts from them, or could just ask them the price and size. But still need to get the front sensor. Can't find it on eBay or anywhee else.
