Mk2 Xenon Headlamp Retrofit
383 replies to this topic
#166 Megado
Megado
  • Budding Enthusiast
  • 165 posts
  • Name: Sepe
  • Ford Model: Focus 1.8TDCI Titanium
  • Year: 2009
Posted 22 June 2014 - 11:18 AM
If that connector had little Y on center, it's same. I've just unplug it ja plug back again, and push it to bottom far as i can. Mine problem was that Instrument cluster does'nt show anything. So that connector has connection to Instrument cluster and ignition control.
Have something to contribute?
#167 nazsky786
nazsky786
  • True Ford Enthusiast
  • 571 posts
  • Name: Naz
  • Ford Model: FOCUS MK2
  • Year: 2005
Posted 22 June 2014 - 11:21 AM
Yh has a tiny Y . It's has the starter cable going to it. I might check that connector.
#168 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 22 June 2014 - 12:43 PM
Yes it's same connector
#169 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • 1,690 posts
  • Name: Kurt
  • Ford Model: Focus Zetec S
Posted 22 June 2014 - 12:54 PM
Did you guys disconnect the battery before disconnecting those connectors
#170 nazsky786
nazsky786
  • 571 posts
  • Name: Naz
  • Year: 2005
Posted 22 June 2014 - 12:56 PM
Yh. If you don't I think your airbags can have issues as the airbag system is attached. Disconnect battery or you may set off the airbags.
#171 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 22 June 2014 - 12:59 PM
Sure, everytime ill do something like that, I disconnect battery.
#172 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • 1,690 posts
  • Name: Kurt
Posted 22 June 2014 - 01:01 PM
Good. The starting issue may be a result of the various modules setting up. Won't you need to do some work with the ignition megado?
#173 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 22 June 2014 - 01:02 PM
Ofcourse, there's is option set off airbags and aircurtains (if fitted). But after connect battery, i check DTC's and nothing problems.
#174 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 22 June 2014 - 01:04 PM
Actually i disconnect also Junction box, wheres dashloom connects. Dashloom has also ignition parts, so i'd figured out that's problem, now it's working fine :)
#175 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 23 June 2014 - 07:18 AM
So you change loom right? Did you notice are xenon module wires mixed randomly on harness?
#176 nazsky786
nazsky786
  • 571 posts
  • Name: Naz
  • Year: 2005
Posted 23 June 2014 - 07:24 AM
The xenon loom bit comes from all over the place. You have some which go to the blue connector and some which go directly to the outside with the Y connector you mentioned. That's why I choose just to change the loom. Harder to get in but overall way better way or doing it instead of pinning wires etc.
#177 nazsky786
nazsky786
  • 571 posts
  • Name: Naz
  • Year: 2005
Posted 23 June 2014 - 07:26 AM
I think the ones that go directly out are for the leveling sensors. Then the blue connector just carry the configuration info. And the light switch. Don't get me wrong changing the loom is a lot of work.
#178 Megado
Megado
  • 165 posts
  • Name: Sepe
  • Year: 2009
Posted 23 June 2014 - 07:32 AM
OK, dismantle center console first, might easiest way to start.
#179 nazsky786
nazsky786
  • 571 posts
  • Name: Naz
  • Year: 2005
Posted 23 June 2014 - 07:45 AM
Yh dismantle the centre console screws near the back. Then take everything you can off the steering wheel and the dashboard itself. Side kick panels a pillars. Glove box, panels . Then there are screws all at the bottom the top bit off dash is covered by clips just pull.
#180 nazsky786
nazsky786
  • 571 posts
  • Name: Naz
  • Year: 2005
Posted 23 June 2014 - 08:05 AM
I seem to have made the issue worse. I messed with that connector and the airbag light is on now. Going to have to keep messing with it.
Not what you're looking for?
